Question about Mitsubishi MSZ-A15NA Split System Air Conditioner
What does e57 mean on the reader? - Mitsubishi MSZ-A15NA Split System Air Conditioner
  • 10,515 Answers
There could be few reasons for this error :-
1. Refrigerant leak or shortage of refrigerant.
2.Indoor unit heat exchanger sensor [ThiR] is defective (short circuit).
3. Indoor unit PCB defective (defective sensor input circuit).
4. Indoor unit PCB defective (defective sensor input circuit).
A tech is recommended for the exact diagnosis of this error.
Good Luck!!
Thanks!!
Posted on Aug 20, 2010
What does error code E57 indicate?
E57 means that your inverter board is drawing too much power' below link shows where and how,
press the helpful button
GE Front Load Washer Inverter Removal
Jan 25, 2016 | Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
What is error code E57?
E57 Checksum failure Software error occurs - checksum failure. Non-recoverable error. Main control board must be replaced.
Nov 07, 2014 | Washing Machines
ERROR CODE E57 indicates what?
For most questions you should supply as much information as possible, especially manufacturer & model #.
I'm sure error codes are different by manufacturer.
I found this answer for an electrolux;
Regrettably, error codes E57 and E58 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing.
Apr 06, 2014 | Washing Machines
My electrolux EWFLS70JSS front load washer is showing a E57 error and is not entering spin cycle.
Hello Walter, thank you for your post!
An error code E57 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing.
Hope this proves helpful!
Jan 16, 2014 | Electrolux EWFLS70JSS Washer
Bosch logixx 8 E57
Circut board of the motor is demeged.if you take out the board witch is next to the moyoryou will see on the electronic print
The demeg.
Nov 20, 2013 | Bosch Logixx WAS2446 Front Load Washer
I have a GE Energy Star Front Load Washer, Model #GFWN1100LWW and the error message on the screen is E5.7. After unplugging and plugging the machine back in, the message is still there. I called GE...
Could it be E57? If so, this means that the main control board is bad.
"Never disconnect the power to the washer while it is in the service mode. Doing so may result in a damaged control board."
You may want to check this site for more info:
http://www.appliance-repair-it.com/GE_front_load_washer.html
Hope this helps a bit.. :)
Jun 07, 2011 | Washing Machines
Where can I buy new burners for Electrolux Icon E57
http://www.grillstuff.com/gas-grill-burners/?cat=48 Can't find your model but you should be able to use the parts wizard to find the burners.
Jun 06, 2010 | Electrolux Icon E57LK60ESS (LP) Grill
Mitsubishi MSZ-A15NA Split System Air Conditioner Logo
399 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
