Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai plasma tv 5 blinking red lights PDP4298ED
It wont power on, i see the red light go odd responding to pressing the button, i hear the click, no power.. red light on. press it again, it clicks and then 5 blinking red lights. no image on sceen, unable to get it to show menu, etc. I may replace the power board first,-- but could it be something else? the main board, or the 2 above it,? it seems a easy fix to me, anyone had any luck here? thanks so much!!!! i have photo's too...!!
  • 17 more comments
  • DodgeA May 03, 2008
    I have the same problem. The voltages are wrong on the Powersupply, however I replaced the powersupply because the service manual had said to in this case, but it did not resolve the problem.. I'm not sure where to go with it now.
  • Kris Luettchau
    Kris Luettchau May 05, 2008
    thanks DodgeA, do you happen to have the service manual? the search is illusive. Crossing my fingers, i hope the power supply fixes it. I'd say next, try the mainboard under the two siamise twin boards at the bottom, under the plate (another set of screws) and there is the main board... I wanted to try to replace the cables to, but what can you do. still trying, Let me know how it goes!
  • Kris Luettchau
    Kris Luettchau May 09, 2008
    Saw some of it. Are you speaking about the blown caps situation? well we will see, I got a replacement board, will see if fixes issue. (the replacement board is also broken, but i fugure with 2 boards, i can use parts. We shal see )
  • Kris Luettchau
    so....
    Here is my board that i ordered for replacement, as you can see, the
    top left second in --cap IS BLOWN. so i think i can either, use a cap
    from my other board into this and see if it works, or.....test out my
    current board, and use this board for parts.
    any suggestions, that be great.
  • Kris Luettchau
    Board.
  • Kris Luettchau
    here is 2 reds. will change em out first...good to know..thanks!
  • Kris Luettchau
    I do have two of them, one is blown, and not on the heatsink.. I just went to Fry's and couldn't find it as a replacement. . It seems i need part- c524... also c523 (other one you told me to replace) , but no listing on the part.. just: P0.22K400, COULDN'T FIND ANY .22K OR 400V at frys.. found 222k, and .22 but only 125v..so... i might pull them off my other board and put them here. we see. getting ot of my hands a bit.
  • Kris Luettchau
    Kris Luettchau May 10, 2008
    Definately. thanks It' interesting, one board shows P0.22K400, and is a "SHINSHIN" , and the other shows P224K 400 and is also a shin shin but right below the lettering is T07. i can see it is bulging, but still in the plastic.
  • Kris Luettchau
    Kris Luettchau May 13, 2008
    Ordered them. they ran about 2.02$ a piece. it's the .22 you want to get... the .00 and the .0 are too little. it's a .22uf.. i saw those little ones at fry's. no go. ordered these fromhttp://www.tubesandmore.com/, they run out of Arizona.. Let you know when I get them. Oh! and remember to use a heat diffuser when soldering can bust the drop at least it's what i read. what do i know...... between the drop and the board, just use a aligator clip or something to difuse.. Let you know when i get my tv up and running.. (crossing fingers)
  • Kris Luettchau
    Kris Luettchau May 14, 2008
    Got a plasma tv free, guy said it was power supply wont turn on just red light.... no sound no tv... all.First plasma attempt open for me. Anyhow, i got a second board on ebay for 10bucks, (thought i could use it for parts).. both seem so so... but when i took your advice, i took a closer look and all 4 orange drops are swolen/ one busted. so im going to try to replace this first. I still dont know what 5 blinking lights mean, or how to check the voltage using a micrometer. So im winging it, i have friends who solder, so that' all im doing. Got any suggestions otherwise?
  • Kris Luettchau
    here is the piece.
  • Kris Luettchau
    Im really glad about your positive outlook on fixing the problem. So this replacement method solved your issue take it...i hope it solves mine also. I did order about 6, so i have a few extra case the soldering job gets boffed. IT seems simple enough, about the widest spaced solderpoints on the whole board. should be here by Friday. Whooot! (Fingers crossed)
  • Kris Luettchau
    It's very
    easy to measure the voltage. Sometimes requires a steady hand though. All you
    need is a multimeter or voltmeter. One can be had at Harbor Freight Tools for
    $3 which is very cheap for an ok multimeter. I have like three of them. They
    usually run $20 at normal retail. There is two probes. A black and a red. With
    the board in the tv and powered on, use the black probe to touch the aluminum
    backing of the tv set and with the red probe, you can use either of the white
    connectors at the top sides of your ps board because they have the same pins.
    They each are labeled like VS for each pin in the connector. Use the red probe
    to touch that pin. You should get a reading of around 90v. The voltages should
    be listed on the aluminum backing of the tv screen near the top right on a
    sticker. If you need the voltages just let me know.
    "---Tersmurf
    thanks man, will check this.
  • Kris Luettchau
    Kris Luettchau May 18, 2008
    I got great news!! putting one of those little caps in there, that i got from a local elec store, rvac i believe. it's a green cap nopw, but same volts etc.. soldered it, and poof. it works. so that board i got payed off. WELL,.. all in all, i got a 42 inch plasma tv for Cheap. Good times, thanks for all your help. I may still keep/fix THE OTHER board, but for now, it's working and im leaving it alone. thanks! Whoot
  • Anonymous Aug 23, 2008
    I have the same problem but just visually looking at the red capacitors they look fine
  • jaburto Oct 16, 2008
    Does any body know if part #C-TD22-400 from www.tubesandmore.com will work?
    They can't figure out the right part you are posting.
    Thanks,
    jaburto
  • Anonymous Nov 24, 2008
    My TV went bad again. I'm assuming it's the same cap we just replaced. Lots of smoke!
    julio
  • jaburto Dec 04, 2008
    Any idea where I can get a new board for Akai PDP4294 ?
    I'm affraid of replacing that cap again and then running into the same issue.
    Tks,
    julio
  • morav1 Dec 26, 2008
    I have no video,sound. Power supply visually looks good. Checked all fuses. good. No power VE, VA, etc Voltages present. Bad Power supply? If so, where can I get a supply or schematics? Thanks, Mike
    Problem Solver:
  • 17 Answers
Have you guys checked out my solution in the troubleshooting and support for this same Akai model?
Posted on May 08, 2008
  • 6 more comments
  • Ter Xiong May 09, 2008
    Have you checked the voltages on your board? In my board the VS voltage was low. It could be that cap on yours. Try to replace it. All the caps on my board were all bloaded and looked like they are going to explode but after replacing them, it didn't solve the problem. Try this. In your picture, there is a capacitor that is a brownish red color. It is between the 2 green transformers and the long heat sink with that orange circle sticker. There actually should be 2 of them. In your picture there's only one. It will still work with one but 2 will help. Try replacing those and see what happends.
    Oh you do have 2 of them. Sorry I didn't see the second one sitting on the heat sink.
    Probably the only place you can find it is online. Like digikey.com or futurlec.com. I like digikey because they are running 24 hours. Futurlec is nice and has many parts but the shipping takes long. Like a week and a half. There parts ship from Thailand so that probably makes it take long. About the part, no ones certain of what value the cap is. It's either .022uf or .0022uf. The caps are very cheap. Like 15 cents each. I may just order both sets and put them in and see what it does to the voltage. I'll get extras incase people here need them.
  • Ter Xiong May 14, 2008
    Ok now back to the beginning. So your tv went black and you ordered a new PS and it didn't work? So you have two PS?
    $2.02 is a little high priced. Actually should be about half for one but it's ok. As long as it works. The good thing is that it's closer to me in California. I shop at digikey.com but they are in Minnesota. At futurlec.com most parts are only around 15 cents but they are in Thailand and shipping takes a very long time. About 2 weeks.
    Ok. So I guess the new board you ordered on ebay didn't work then. I was just wondering why you needed to fix when you already ordered a new PS. So both boards have the same problem. Hope you ordered enough caps for both. Replace the caps on both boards and test both boards to see if the tv works again. That means you'll have an extra working board. That'll be good. A spare or you could sell it.
    What I did was used the good PS's caps and put them in the bad PS. Now the bad PS works so now I know that all I need is replacement caps for the other board.
    I wonder why other people don't comment back on this site except you. Do they need help or what? I wish this site was more like a forum. That would make it easier.
  • Ter Xiong May 15, 2008
    I got my new caps. Was going to order but decided to check out this electronics shop I usually go to. I don't like to buy stuff there because it's very expensive. They quoted me $5 for a transistor that I bought online for 50 cents. I checked it out anyways and saw the caps I needed. They were $1.70 each which is not too bad. So I bought 2 of them for my PS board. I soldered them in and now my power supply board has normal voltage to the VS again.
    Here are my new caps.
    Old one on left. New one on right.
Type 224K 400v on ebay which should display a orange capacitor as this is the correct part for a po.22k400 shinshin (0.22uf 400v), paid $14.99/ £9.10 for 90 capacitors, common problem for 42" plasma which has no image displayed when turned on but can hear sound.
-------------------------------------------------------------------------------------------------------------------------------------------------------- Ozzy...E7
Posted on Jul 21, 2009
    New Friend:
  • 7 Answers
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Akai plasma tv 5 blinking red lights  PDP4298ED - a792bb6.jpgAl
What if I use a 630V instead of a 400V cap? what's the risk?
Posted on Nov 17, 2009
    Problem Solver:
  • 6 Answers
Removed the two caps and read PO.22K630
Can someone tell what this all means and why Samsung changed from the previous values. the board is V3 bn96-012117a
Posted on Nov 23, 2008
Oops.
24mm long is what it should measure, not 22mm
julio
Posted on Oct 30, 2008
I was unable to locate those caps in the Los Angeles area.
I got 2 caps from Electronics Supply Co, Inc in Kansas City, MO (800)669-3752 www.eskc.com.
It's an NTE brand part number MLR224K400 and this is NTE's data sheet for this part http://www.nteinc.com/capacitor_web/pdf/mlr.pdf
You want to get a .22 cap that's 400V and it measures no more than 22mm long.
Just a couple of bucks each plus USPS.
My TV is back in service since a week a go and I hope it'll stay like that for a long time.
Thank you all.
julio
Well, it';s been a while and my tv is still working, so yea, it fixed the issue.
I got these caps at a local repair place caled RVac, or i think it changed names. anyways, i brought it in and they gave me a green one to replace. works fine. color not important, just take #'s down, or take cap to location hope this helps.
If you haven't solved your parts problem yet try shopjimmy on ebay. good luck
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Code for a universal remote control used on a akai. No codes listed in the instructions for using will work with an akai television set
Hello
Three digit universal code for Akai TV are:
002/ 003
Four digit universal remote codes for Akai TV are:
0105 0002 0077 0254
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 19, 2011 | Akai Televison & Video
MY Pioneer Plasma PDP RO6U is not responding. The Standy light and Rec Time lights were both red and would not turn on either by remote or by pressing the on button on the receiver. I have unplaugged it...
DO any of the lights blink when this is happening? Do you hear any clicking noise before the lights turn red. I mean multiple clicks?
Please provide this info so that we can continue with the diagnosis.
Sai.
Jun 06, 2010 | Televison & Video
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
AKAI PT5598HD won't turn on
take it to a repair shop and have then look at it. it may or may not be worth the cost of the repair. i dont know what the parts and labor would be on it
Nov 15, 2008 | Akai PT5598HD 55" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
5,061 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
