Question about Vacuums
Hi. Tried to do toasts this morning but to my dissapointments it has refused to work. I changed the plug fuse- no difference, still not locking when pushed down. Any idea what it could be?
  • 17,130 Answers
The heating coils or the contacts have burned out. It is a simple device and you can DIY. Open the panel and look at the switch that contacts when pushed down. This contact could be burned or dirty try to clean and set.
Use a multimeter to check the coils if open find the spot of continuity and join with a resistive wire. It might help to toast for some more time.
Posted on Aug 20, 2010
Dyson small ball multi floor vacuum cleaner purchased in Australia
Aussie electrical current may be different than our US current. England's is. Converters are needed to plug in a toothbrush in England. Likely Australia is the same. We've lived on a dirt road for 32 years, in New Mexico. We call dust "enchantment." Mostly ignore it. Check out the electrical conversion from them to us. Likely there is way to convert their currency? to ours. Electrical currents.
Jan 03, 2018 | Dyson Vacuums
Easy Flo SQ9020 stopped working - what should I check to identify what the problem is?
I am assuming you have checked the breaker that it is on? Have you tried using it at a different outlet?
Jan 10, 2015 | Easy Flo Vacuums
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
Brand new Bissell Healthy Home 5770H Upright will not turn on.
If the brush attachment isn't locked into place than the vaccuum will not work make sure it is attached properly.
Jun 18, 2009 | Bissell Healthy Home HEPA Bagless Upright...
No power for the vacuum
Hi! I work at repairing Sebos, so can certainly help.  Most probably the cable is damaged, and the two most likely places for that to happen are where it enters the plug and where it enters the rewind mechanism. Before you even think about dismantling the machine to get at that end of things, though, you need to be 100% sure that power is reaching the machine.
I know you've tried a different socket, and that you've changed the fuse (by which I assume you mean the plug-top fuse, and therefore that you're probably in the UK like I am). Good first steps. Checking the integrity of the wire in the cable is a different matter, though. There are inexpensive devices you can buy to check for voltage through normal insulation, but I don't know how deep in to this you want to get...  you've got to be pretty keen (and competent) to think of changing the cable yourself.
If you'd like to post a response, indicating how far you want to go yourself, I can help you get in to the machine if necessary.
May 25, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
No steam from my almost new Polti 2600
It sounds like the solenoid isn,t activating when you pull the trigger which then lets the steam out. It either wants stipping and checking or returning to where it came.
Apr 19, 2009 | Polti Vaporetto 2000R Vacuum
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Accidentally plugged into 220 volt outlet
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Nov 05, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
