I dont know how to hook up my rca receiver to my dvd player and my tv and vcr so i can have it all running i dont know what wires go where
  • krskruising Nov 22, 2008
    I have the same problem except I also have a Direct TV box. How do I connect all these to my KR-V7080 receiver?
    Novelist:
    Champion:
  • 236 Answers
First check your receiver if it has inputs for all those gadgets you wanted connected. in your input function selector see if there are options for your dvd, tv, vcr. if it does have all those inputs then just connect all the audio output left/right rca jacks of your gadgets to each input function of your receiver. your VCR though is different, you have to connect the receiver input to vcr output. the vcr record goes to the vcr input connections. your TV, if it has got any audio out then connect to the audio in function of your receiver.
Posted on May 03, 2008
What color wires do i need to hook up the vcr player? The dvd player works with red/blue/green
Colors dont matter as long as you hook video on VCR to video on TV witch is usually yellow and left and right audio to L&R audio on TV witch is usually red and white.
Jul 17, 2011 | RCA Televison & Video
We just purchased a Samsung TV, and have been using a RCA DVD/VCR player/recorder, Model#: DRC8295N, Serial#: XXXXXXXXX We have Direct TV and before the new tv was using one of their DVR player/recorders....
The problem with your DVD/VCR is that when you hooked up your new TV you probably removed the power cord for the DVD/VCR during installing and running your new wires and such.
Your DVD/VCR has known problems in the power supply. This is very common. When unplugged, this allowed the capacitors to discharge and now wont work at all. It is very possible that if you left your DVD/VCR plugged into the AC wall socket it might begin to work after a couple of days. I wouldn't plan on it though.
Your DVD/VCR will need power supply repairs.The cost should be around $100 dollars.
if you would like one of our stores to repair this for you we would be happy.
please visit http:www.albiontvandcomputer.com
You can send us the unit and we can repair this for you and return in about a week.
Jan 18, 2011 | RCA DRC8295N DVD Recorder/VCR
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
How do i get to the input/video screen on the RCA F32672sb 32
If you have an old vcr hook the dvd player to the inputs on back of the vcr (RCA jacks) Run a coax cable from the "out" on the vcr to the back of tv. Turn the tv on channel 4 or 3 then put a tape in the vcr and push record then pause it. Or if the vcr has a tv/video button you can push or activate it and it should allow the dvd to play through to the tv.
Feb 10, 2009 | RCA F32672SB 32" TV
Yamaha htr5230 hookup
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
Sep 01, 2008 | Yamaha HTR-5230 Receiver
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Help with my tv
some tv's dont come with rca jacks, what u can do is run your rca's through a vcr and then the vcr to the televison u can do it that way, or take and buy this thing they carry at radio shack, it is a devise that you can hook your dvd player to a junction box that hooks into the same place as a vcr would in the back of your tv, hope this helps jason
May 14, 2007 | Sharp 25H-M60 TV
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
134 people viewed this question
 Grubhead
Grubhead
