Question about Philips 42PF5421 42 in. LCD Television
My Philips 42PF5421 tv keeps blowing the fuse. I have tried three in as many days but pop! I am replacing it with 3amp. ANy ideas?
  • Ben Dover Aug 21, 2010
    follow welcome Jee advice, you be glad you did
  • 10,594 Answers
3.15A fuse is correct one, if it gets blow that means power supply board is defective and will be replaced.<br />I disagree with *<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Buldging Capacitors* idea because output chips are shorted out in power supply board and blowing fuse that does not happen with bulge capacitors.<br />Power supply board part number is </span>310432836212 and price would be around $140 or so<br /><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Thanks.<br /><br /></span>
Posted on Aug 20, 2010
  • Shahid Electronics
    Shahid Electronics Aug 20, 2010
    Sorry about above post that got messed up with unknown reasons.
    I
    disagree with *Buldging
    Power supply board part number is 310432836212 and
  • muebe Sep 28, 2010
    Great answer Jee from one of FixYa's Great Online Techs!
  • Philips Master
  • 3,866 Answers
The power board is what is my concern here.
Things to check
1. Buldging Capacitors
The power board is in distress if its poping that many fuses, I would just have you replace the power board.
Your full model number was not displayed is it a 21 D, B or C
you can find the part HERE
thanks and be sure to rate
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
Enerson lc401em2f
Buy a replacement and pay for the extended warranty.
Dec 18, 2012 | Emerson Lc320em1 TV
Fuse keeps blowing on my Philips 32pw8608/12
Please, never try to replace a fuse, without checking for any short circuit inside. You will only increase the damage inside. It is advisable to call in a qualified service technician as opening back cover by unqualified personnel is hazardous.
Aug 15, 2012 | Philips Televison & Video
H2520 fuse blown
check wiring make sure correct voltage also check to see if you have a shorted wire
Jun 16, 2012 | Hayward H Series Pool & Spa Heater 200k...
My 2001 ford excursion keeps blowing fuses to the windshield wipers the moment I go to turn them on, any idea on what to check or replace to get rid of the short, or where it might be?
Doing electrical testing is the way to find the short , not looking for magical fixes on here ! If you don't know how to use a volt meter an read a wiring diagram , your best bet , take it to a qualified repair shop .
How to Diagnose and Find Short Circuit or Wire in Your Car
Jun 21, 2017 | Ford Excursion Cars & Trucks
My Philips 42"lcd tv modle
The parts on the Power Supply module will be to difficult to locate so the best thing is to replace the power supply board. The power supply is in stock at www.shopjimmy.com
The price is $83.96. Just enter your model number and follow the directions.
Nov 28, 2010 | Philips 42PF5421 42 in. LCD Television
Blowing 3amp fuses
You have a low voltage short. A lot of low voltage shorts come from the wires that go out to the outdoor unit. Go outside and inspect those wires and that they are in good condition. Also check for any splices in those wires that they haven't degraded in any way. This is the only thing that will blow the fuse. That's why it's only 3 amps and based on the size of your fuse, it's a gas fired unit right? Have a great day!
Apr 10, 2009 | Ruud UBHC Air Conditioner
Hi watching tv and it just switched off
first of all check out the tv power cord wire is it fine or seems like it got cut from some where or do you get any burning small from the wire.if this the case then repair that wire.if the wire is proper then try that wire in another electric outlet.if everything does not works.then is naturaLLY the internal board error.any of the capacitors or the ICs have gone short .the faulty 1 should be checked and replaced.
Nov 30, 2008 | Philips 42PF5421 42 in. LCD Television
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
The whole system won't turn on
Go to Logitech support and check the faq's on your speakers. You must replace with the same fuse and it may be a 3amp slow blow fuse. If so replace with the same fuse or you will just keep blowing them out.
Jan 11, 2007 | Logitech Z-5300 Computer Speakers
Philips 42PF5421 42 in. LCD Television Logo
587 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
