Question about Microwave Ovens
I need a new gasket and cannot buy one in any local shops
  • 3,037 Answers
Try repairclinic.com for parts, just need your model number to search for the right one
Benjamin
Posted on Aug 20, 2010
Where can I get an internal thermal fuse for my Panasonic Microwave NN s335wf
Any local appliance repair shop will have this fuse, but you need the old one to match it to the new part. Check your Yellow pages phone book.
Aug 19, 2016 | Panasonic Microwave Ovens
How to get a new glass turntable
from the manufacturer spares department
from an appliance repair shop
from the service dealer for the brand
from your local salvo, st vinneys shop
Nov 30, 2015 | Emerson Microwave Ovens
Brand new and has never worked,
Take it back to shop , or advise supplier if not bought from shop, local. They legaly obliged to give you a new replacement , as the one you bought is defective, NO REPAIR , GET A NEW ONE
Mar 16, 2015 | Microwave Ovens
Outer glass shattered, removed it, cleaned old gasket,got new glass, can't find where to buy new seal and gasket.
try using http://www.allbrandonline.com/Default.aspx?Page=My%20Account%20Profile click this link it is one of the cheapest appliance parts suppliers that I have found and this is my 12th year in repairing appliances if they do not carry your part please message me back the make and model number and I will look further into where you can obtain your part Thanks Rick
May 20, 2011 | Microwave Ovens
Cardboard cover is broken in the microwave>
The cover is the waveguide cover and must be replaced to keep the magnetron free from steam and food particles. Your local microwave repair shop can do it quite easily or you may be able to buy a mica cover online.
Mar 28, 2011 | Danby Microwave Ovens
My microwave, GE Spacemaker, stopped heating. What do I need and
please rate ?
some models had a five year parts warranty on the magnetron those are usally 80-160 dollars. if not in warranty then u would be charged that and probably a service call around 80 dollars and prob labor to install it which would be around 30 dollars because to inspect it and install the part u must remove the micro if this is a over the range hangin micro.
this is the worst case scenarion it always could be an internal fuse, diode, or thermostat on some, but wont be known until inspected by technician, i know some local shops that service these for cheaper if u can remove the unit and bring it to thier shop.. Also depends how old it is it might be better of to buy a new one if your gettin near 7-10 years
hope this helps good day mate
Apr 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need replacement lamps for under micro--surface light
Voltage will be the same as your household and the appliance, and 99% of the time that's 110 if you're in the US.
What matters more are 2 specific shopping details; Wattage and base size (width)...The first detail is stamped/printed on the original bulb, and base width (not diameter) is easy to determine by laying the old bulb on a ruler.
Overall bulb size doesn't vary much, and is easy to match at the supplier.
Which was the other part of your question: Where to buy.
Most Walmarts carry a small selection of appliance bulbs, as does the local HomeDepot...You will need those 2 shopping details to zero-in on the replacement, then verify that the overall size of the glass is the same of smaller.
(A bit smaller is OK, provided the wattage and base-size are the same...but too wide or too tall, and you can't get the cover back on.)
Best Buy can order the bulbs for you if their service dept doesn't have it in stock, and Sears offers the same service.
When all else fails; Hit the Yellowpages under "appliance parts" for a local parts shop...The bulbs are for the most part fairly generic, and any decent parts shop will have a few in stock.
Mar 28, 2010 | GE XL1800 1100 Watts Microwave Oven
My light in the microwave has gone out. Is there
Bulb replacement was designed into the appliance, meaning that; Yes, you can replace it and it's rather simple.
First, UNPLUG the appliance! You're working with the door open, so the bulb socket is hot (charged) even though the bulb is dead.
For the overhead light, the bulb is located behind a plastic splatter-shield that clips in place...Press the clips in to remove the shield, and un-screw the bulb (lefty-loosey).
For a sidewall bulb, there are the same clips holding it in place, but they are recessed and you may need a butterknife or to pop them out: UNPLUGGED, RIGHT?
What matters most are 2 specific shopping details; Wattage and base size (width)...The first detail is stamped/printed on the original bulb, and base width (not diameter) is easy to determine by laying the old bulb on a ruler.
Most Walmarts carry a small selection of appliance2_bing.gif bulbs, and your local Lowes or HomeDepot have a few more to choose from...You will need those 2 shopping details to zero-in on the replacement, then verify that the overall size of the glass is the same or smaller.
Mar 28, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
