Question about Dishwashers
My diplomat dishwasher is not dissolving the tablets even on a hot temperature, what can i do?
  • rebecca_mann Aug 20, 2010
    Thank you for you speedy response. They are being washed properly it's just the tablet ends up in the bottom of the dishwasher. (I tend to rinse the food off in any case) I've put it on twice today to dissolve the tablet.
    The compartment does come open, it's just the tablet falls to the bottom of the machine.
    Genius:
  • 1,036 Answers
Check if the circulating pump is actually working - are the dishes being cleaned at all ? If not - check pump for operation and replace if faulty.
If tablets are still stuck in a compartment - replace operating mechanism for tablet drawer, or - cheaper - put tablets in with the cutlery instead.
Posted on Aug 20, 2010
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
Think the element or thermastate has gone as it's not disolving the tablets can I fix it myself
One of the first things to check if the dishwasher detergent is not dissolving is the water temperature that is in the dishwasher. If the water temperature is too cold, it may not be able to dissolve the tablet effectively. . If it is below 130 degrees Fahrenheit the setting needs to be increased or contact a plumber for assistance.
Read more : http://www.ehow.com/info_8597080_dishwasher-tablet-not-dissolving.html The Dishwasher Tablet Is Not Dissolving eHow
Nov 18, 2015 | Dishwashers
Detergent tablet will not dissolve?
Check water temp in might be to cool that is the first step......
Oct 06, 2014 | CDA WC430 Dishwasher
Dishwasher tablet not dissolving when dishwasher beingrun
is your water or water temperature setting too cold? The hotter the water the better chance to dissolve the tablet.
Maybe try running on the heated or sanitize cycle to see if it works better. I always run the sink tap until there is hot water coming out before turning the dishwasher on....
Sep 08, 2013 | Smeg 18 in. STX45-1 Stainless Steel...
Tablet not dissolving, and dishes dirty
Hi,Nicole, try this:
Run the water nearest the dishwasher (usually the sink), getting the water as hot as possible immediately before starting the dishwasher. This will help getting the tablet to dissolve.
--Best regards, --W/D--
Apr 05, 2011 | Bosch Dishwashers
Hi I've got a diplomat dishwasher but the tablet keeps dropping into the cutlery department and is not dissolving I've tried putting it on the hottest wash puttng the tablet in one of the trays but...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 23, 2010 | Dishwashers
My whirlpool dishwasher is not releasing the tablet and not doing a cycle wash. Some cold water is going in then it bleeps it is finished.
your machine should only get hot water going into your machine .that is the problem right there,chek faucet temp then start machine must be hot going in.the tablet even if was dropped will not dissolve in cold water. let me know if i was helpful to you
Feb 24, 2010 | Dishwashers
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Detergent tablet didn't dissolved
Welocme
If the tablet did not dissolve this means either your soap dispenser door did not open, or your water is not hot enough. let the hot water tap run till it comes out hot before starting the dishwasher.
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign off. Huum
Dec 22, 2008 | Dishwashers
Dishwashers Logo
575 people viewed this question
Top Dishwashers Experts
