Question about AEG 24 in. Favorit 80850 Free-Standing Dishwasher
Aeg favorit code c3 - AEG 24 in. Favorit 80850 Free-Standing Dishwasher
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 20 Answers
SOURCE: I need an manual in english for the AEG Favorit
try here. http://www.serviceforce.co.uk/pdf_search.asp
Posted on Jan 21, 2010
I have a oko favorit 4071 doesnt start and display H8 error.
I think this is not the error code. I belive this is hardness of water (could be set from 0 or 1 to 10, depending of model. Read your user manual how to exit the program for adjust the water hardness).
Error code for your appliance depending on model and look like:
i10, i20,i30............ or
C1, C2,C3.............
Dado
Jul 06, 2015 | AEG Dishwashers
Why C3 code on dishwasher favorit 5081
Problem with inlet water.
Could be: water tap closed, pressure switch....etc
Dado
Jun 19, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Error c3
http://www.aeg.co.uk/Support/Troubleshooter/?Command=Detail&CatId=98&SymptomId=1412&DetailId=1412shows AEG's meaning for a C3 error code
Feb 06, 2013 | AEG Washing Machines
Aeg favorit 88080 service code i30
In my case, it turned out that the faucet was completely clogged with scale deposits. Replacing the faucet solved the problem, so by all means, check this before you take any other action!
Jul 10, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Error code C3
LOOK IN YOUR MANUAL...IT SHOULD HAVE A SOLUTION TO THIS CODE..JUST FOLLOW INSTRUCTIONS...BEST OF LUCK..
Jan 11, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Oct 24, 2007 | AEG Dishwashers
AEG 24 in. Favorit 80850 Free-Standing Dishwasher Logo
76 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
