Question about Electrolux Washing Machines
The washing machine trips the circuit board every time it is on...is this the heating element, drum or other?. easier to fix or get new one?
  • Electrolux Master
  • 17,130 Answers
Check with the different programmes, to make sure when the tripping comes into force. If during the heat wash , then possible shorting in heater but if random please ceck the motor capacitor and change it . I dont think the issue is very much if the machine is running at other times, but if this trips on switch off , it can be easily identified byt a circuit check with a multimeter. maybe motor , capacitor, surge protector. Check this out, Helpful?
Posted on Aug 20, 2010
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
My whirlpool awo3761/s keeps tripping my electricity when water is inside the drum
I would turn off the machine and unplug from the wall. Water is conductive and if it is throwing your switch you need a professional to look at it. Ring your local washing machine mechanic. Electricity and water are just too dangerous. If you keep resetting your switch and trying to run it, just to have it reset again, you can burn out the switch in the board. My husband did that when the kettle kept tripping it. New switch in the board was about $300.00.
Feb 06, 2015 | Whirlpool Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Bosch Washer: drum hits heating element
A picture of the damaged element would help. How old is the washer? Perhaps the washer timer or control board is feeding current to the element at the the wrong time, without water in the tub, causing the element to deform and burn out.
Are you certain that the replaced element is sitting in the support groove and not above them inside the tub? Take a flashlight and have a look before inserting the new element.
Oct 30, 2017 | Bosch WFL 2463 Front Load Washer
HOOVER HNF 7147. BLOWS THE HOUSE RCD ONLY WHEN ON A WASH CYCLE AND NO WATER BEING FED INTO DRUM. I SUSPECT THE HEATING ELEMENT IS DRAWING TOO MUCH DUE TO NO WATER IN THE DRUM. BOTH INLET VALVES ARE OK AS I...
You need to check the circuit in the wash cycle. Disconnect the power to the heater coils and see if the fuse trips. Also the voltage at inlet solenoid must be checked when the program cycle is on the wash , is not the program controller board is fault, possible a wrong output from the processor.
You can isolate the circuits, the heater, the motor drive to see if the trip stays. Also check the inlet and the drain pump on a test bench to confirm the working of the valve which will infer the case.
Sep 16, 2011 | Hoover Washing Machines
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
Keeps tripping out my down stairs sockets.checked the wires going to the machine and the plug.all seem fine.? Please help
IS BEARINGS OK IN DRUM IF NOT THE DRUM HAS GONE THROUGH HEATING ELEMENT ...TURN DRUM BY HAND IT SHOULD BE SMOOTH .. OTHERWISE CHANGE HEATING ELEMENT.
Feb 27, 2011 | Indesit W 123 Front Load Washer
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
159 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
