Question about Siemens Dishwashers
HI I have a extraklasse SE24A230GB/17 - it won't stop washing - I've tried to reset , checked filters are clean, checked no blockage in out pipe but it won't drain or stop washing . Can you advise please ? thank you Karen
  • karen99cave Aug 20, 2010
    My problem is with my dishwasher
  • 909 Answers
Sorry to tell you, but the board will need to be replaced.The micoM.(processor )is corrupt.
Posted on Aug 20, 2010
  • Siemens Master
  • 12,061 Answers
The water inlet valve is stuck open, you will have to replace it, or if your a DIY unplug washer, turn water off, both valves,
pull washer out, theres plastic valve with wires running to it.
and a hose, [where the water hoses hook up to washer, ] remove the valve, remove the screws that hold the top barrel on to the val;ve, clean valve seat , check fo wear, theres a little round slug that has a seat on it, and is spring loaded, see that it moves freely into coil housing, put it back together,
Also have look at this post below, although NOT your exact model, they are all similar and this most likely apply as well.
http://www.selfhelpforums.com/archive/index.php/t-5111.html
  • Check and make sure that the washer is plugged in. I know that sounds stupid, but washers move and it has happened before.
  • Check and see if the washer works during the rinse cycle. if the motor moves then skip to step 3 If the motor does not turn then you need to test the power outlet. use a small hand held appliance like a hand mixer to make sure the outlet has power. If the outlet has no power you need to check your breakers. If the outlet has power you need to call a repairman for your washer.
  • Good news because your washer works on the rinse cycle your problem may not be that severe. First check to make sure your lid switch is working. The lid switch is a safety device that ensures that the lid is closed before the machine will begin the spin cycle. to check the lid switch simply close and open the lid several times. each time you close the lid you should here a distinctive click. if there is no click then you need to replace the lid switch. if the is a click continue to step 4
  • Ok you have power and you lid switch is working that means you have one of two things going on. 1. you have clog in the line or 2. your pump is burnt out. To check for a clog start at the back of the washer and remove the drain hose. Be ready for water! It may come pouring out. if water does come pouring out then you need to check the drain hose for a clog. If there is no clog in the drain hose then you have a bad pump and it will have to be replaced. If water does not come out when you remove the drain hose then you have a clog. the clog is either in the pump or in the upper hose that runs from the tank to pump.
  • Posted on Aug 20, 2010
    Zanussi 1250 washing machine FLS 1383 W does not drain
    Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
    Jun 20, 2013 | Zanussi Washing Machines
    Washing Machine won't drain away water.
    Hi, can you hear the pump running when you select a drain program?
    Mar 11, 2013 | Washing Machines
    Duets washer won't drain
    Probably a blocked filter, outlet pipe or pump.
    Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
    Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
    Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    The brush is slow or won't turn at all on my Dyson animal DC32. I have cleaned everything including the filtres, there doesn't seem to be anything blocking the pipes. I am in Spain and there
    Hi Jennifer,
    I'm sorry to hear you're having difficulties with your DC32 Animal. If you've been unable to resolve this issue after checking for blockages and washing the filter, I'd encourage you to give the Dyson Spain Helpline a call on 902305530. Alternatively, if you email asistencia.cliente@dyson.com, someone will be in touch as soon as possible to provide assistance.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Apr 17, 2012 | Dyson DC15 Animal Bagless Upright Cyclonic...
    The filter camber on top pops and the air stops coming thru the whole vacuum cleaner. checked filter and washed said filter. Still happens. It is a loud pop and the air noice is loud. It pops when I pull...
    I'm sorry to hear you're having difficulties with your DC15. From what you've described, it sounds as if the relief valve is activating - if you've already washed the filter, it may be activating due to a blockage in the machine. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=813&product=DC15-SY-STD
    Although I note you've already washed the filter, you may want to take a look at the video below to make sure you've cleaned it as recommended. In normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
    This should resolve the issue, but if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Jan 23, 2012 | Dyson DC15 All Floors - The Ball Bagless...
    Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
    I have a zanussi zwf1432w aquacycle.
    Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
    Can you help.
    Cheers
    Apr 05, 2011 | Washing Machines
    Washing machine won't drain
    Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine again before using it again.
    Apr 02, 2011 | Miele Washing Machines
    Whirlpool washing machine "clean pump" error light.
    take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
    Mar 09, 2010 | Whirlpool Washing Machines
    Hi we have a hotpoint washing machine. the machine is some thing error . eg...check out let pipes
    That means it is not draining the water for one reson or another.
    Check the drain hose is clear of any blockage or obstruction.
    If it has a removable filter at the front, then take it out, and clean it.
    If the outlet pipe goes into your sink waste, disconnect the connection onto the waste and check for blockage there.
    Try pumping the water into a bucket to check for flow.
    Plz rate my soluion.
    Thanks.
    Dec 29, 2008 | Washing Machines
    Dishwashers Logo
    173 people viewed this question
    Top Siemens Dishwashers Experts
    aliasger yq
    Mike
    Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
