Question about RIM BlackBerry Pearl 8100
My hpIpaq locked and does not recognize my pass word
My i-mate smart flip phone is locked. When I press on the blue
screen goes up to "Windows Mobile" and it remains as it is.
Please suggest the solution.
Posted on May 03, 2008
Unlocking hpipaq 6515
You can Unlock it simply,You can unlock it easily using the Unlock code,you can get the unlock code and instructions from here
Classicunlocking.com
and Unlock it.
Oct 29, 2011 | HP Computers & Internet
Security light comes on and car will not run. However when security light goes out car runs well. What is the problem?
you car is equipped with a pass key system, this year is most likely a pass key 2, but there is a small chance it is a pass key one, the pass key one has a pellet in the key ( a little black square in the shank of the key ) the pass key 2 has a resistor in in the ignition tumbler assembly ( that is the the key lock but it is called a key and tumbler assembly ) what is happening is the security system is not recognizing your key all the time in either case you will most likely have to replace the key and tumbler assembly, in order to do this you will need to have the system tested to know what the residence value is so you can get the proper key and tumbler set.
Mar 01, 2011 | 1996 Oldsmobile Achieva
I have a iphone that says disable connect to itunes but when i connect it it says need a passcode but i dont have it
Tsk, tsk..
Here's what you do, click here to open a page where you'll the step by step guide on how to put your iPhone to DFU mode and restore.
To put your iPhone to DFU mode means iTunes will be able to recognize your device, by-passing the fact that it is locked with a passcode. But the bad news is, all data in your iPhone will be wiped out.
Follow my instructions carefully to make your iPhone work again. It's better if you read it first before actually performing the procedure.
For more iPhone / iPod touch tips, click here.
Feb 11, 2010 | Apple iPhone 3G
My cavalier is displaying a red padlock image and a wrench image.What do these images mean?
SOUND PASS LOCK SECURITY PROBLEMS.MOST OF THE TIME WHEN YOU SEE PAD LOCK SYMBOL YOUR CAR WILL NOT CRANK.YOUR PASS KEY CYLINDER IS WORN OR THE CAR KEY IS WORN ENOUGH WHERE THE BCM AND PCM DONT RECOGNIZE IT THINKS IT THEFT..
Sep 04, 2009 | 2000 Chevrolet Cavalier
No chip in the key
There is a  security resistor on the key and your going to have to get a new key from GM dealer and  it will come programmed right from the dealer. Once you have the new pass lock keys, your going to have to reprogram the Cars ECM to recognize the new keys and takes about 30 min. You can call a lock smith to come to you and he can cut new pass lock keys and reprogram the car and keys together where you are so you don't have to pay for the tow to the dealer. Good luck and hope this helps.
Jul 15, 2009 | 1991 Chevrolet Camaro
Someone tried to open my phone and enter random security pass and failed. When I tried open it with my codes, it won't work anymore. The phone didn't recognized my real security pass. Please help me I need...
Most nokias go to a hard lock state when many wrong codes are entered. I don't know which model you have, but try this and see if it works. Just connect the phone to a charger and let it sit for 2 hours. DO NOT TOUCH ANY BUTTONS. The try your real security code and see if it works
Mar 14, 2009 | Nokia 6300 Cellular Phone
MY CTS IGNITION WONT TURN BACK AND IT STATES THAT IS IN LOCKED MODE ON THE DASH. DOES ANYONE HAVE AN IDEA OF WHAT IT COULD BE ?
this is a Pass Key anti theft problem, do the following to reset the system, if this doesn't work u will have to take it to the dealer, they are the only ones with the test gear to find and fix the problem
PASS LOCK RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Feb 22, 2009 | 2003 Cadillac CTS
99 olds aurora pass key problem
There is most likely a problem with the tiny sensor in the ignition lock cylinder, it is not reading the key chip and locks u out, the problem is u can't just replace the lock cylinder u need a dealer only re-programm of the pass key system since the control module will not recognize the new lock code, catch 22 if u ask me. Do u have more than one key for the car? do both do this?
Jan 10, 2009 | 1999 Oldsmobile Aurora
Pass lock ingaged cant start car
the chip in the key is not being recognized by the computer in the car some times it will pass in a few hours you will prob need to get your ignition replaced and a new key ..... thats what we had to do with our 02 buick reagal ls
Jul 30, 2008 | 2002 Buick Regal
Hpipaq 6515
get ur msg centre no. from service provider enter it in ur msg settings or else try your sim in other handset good luck !!!
Sep 20, 2007 | HP iPAQ hw6515 Pocket PC
RIM BlackBerry  Pearl  8100 Logo
29 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
