Question about Hotpoint Washing Machines
Hotpoint washing machine WML760G,will not pull water in,everything ok on the water side,seems no power reaching the solenoid valve
SOURCE: Hotpoint washer won't agitate?
hotpoint agitater will not work. how to fix this problem
Posted on Sep 13, 2008
huuum
  • 750 Answers
SOURCE: water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Posted on Apr 07, 2009
  • 30 Answers
SOURCE: Hello, I have a Hotpoint
e11 is a pump fault and e30 is a motor fault there is a possible fault with pcb also
Posted on Jun 09, 2009
SOURCE: My hotpoint wf860 washing machine has no power!
hi guys
Posted on Jun 16, 2009
  • 82 Answers
SOURCE: hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Posted on Jun 28, 2009
Hotpoint aquarius washing machine
If you have pressed start or pulled out the knob of the cycle unit and nothing happens I would be checking the operation of the water inlet solenoid . If it is not getting power or it is not opening the valve to allow filling to commence there will be no further action of the machine until the tub is filled to the desired level.
Aug 17, 2013 | Washing Machines
Hi I have a hotpoint wd72 which is showing an error ' E10 CHECK WATER SUPPLY' when going into rinse mode. I've checked the cold water supply pipe from source to the washer and thats fine, it seems that...
First check the screens in the end of the hose and inside the water inlet valve. If clear you need to remove the top and check to see if you have power to the water inlet valve, there will be a solenoid for hot and one for cold. Check for power on the cold solenoid when washer is put into a fill cycle. If you have power replace the water inlet valve. The whole valve must be replaced. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/washerwaterinlet.html
Sep 16, 2010 | Hotpoint Ultima WD72 Front Load...
My washing machine wont rinsewhen i put it on for a wash
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports (especially on the cold water side). The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer will not operate in cold water
sounds like the water inlet valve solenoid is burnt out on the cold side, hot side is ok. if you have the machine set for a cold water rinse, and the solenoid is burnt out it is calling for cold water and it will not come into the machine. change the water valve.
Mar 02, 2009 | Magic Chef CAV2000AWW Top Load Washer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Won't fill with hot water only
if you have the proper voltage at your solenoid (proper voltage should be on a label on the side of the valve) and you can't feel it clicking on and off and can't feel any water coming out the other side then the problem is your valve is physically stuck close. the valve operates like a piston, when you apply voltage to the valve it creates a magnetic field pulling the plunger up and allowing water to pass. and when voltage is dropped the spring loaded plunger drops back down shutting off water flow. the two things that would cause the valve not to open would be the electro magnet is on back-words or some scale (more likely) has gotten inside the valve and caused it to either not open and close or just clogged the hole
Jun 08, 2008 | Hotpoint WMA33 Front Load Washer
Hotpoint aquarius wf210 g washes but stops at rinse
that is a possabilty, make sure you have water going to cold valves put test bulb on the wires going to valves it should light] close Ire. that means you have current going to valves] get back to me if you can\t sort it
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Cold Water Solenoid Problem
The fill switch has a diaphragm that could be damaged and not closing properly. I have personally experienced this problem before. The way water could be getting by the switch (even with no power applied) is simply water pressure in the lines. I don't understand why it would work during the spin and rinse cycles, however. If you say it's not a pressure switch problem (level sensor), then I would invest in a new fill valve. I hope this helps.
Jul 08, 2007 | Hotpoint VBXR1070W
Washing Machines Logo
52 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
