Question about E-Machines T3065 PC Desktop
Cd player not opening - E-Machines T3065 PC Desktop
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
The cd player has a small hole pres the open button and stick a neddle in the hole and push hard thats the manual open
Posted on Aug 20, 2010
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Why won't DVD player open?
Search Results
    How to Fix a DVD or CD Player That Won't Open - YouTube
    ? 4:53
    https://www.youtube.com/watch?v=RcVn9NUtq0c
    Sep 22, 2014 - Uploaded by doityourselfstan
    How to Fix a DVD or CD Player That Won't Open ... Up next. How to repair a CD/DVD drive that won't ...
    How to fix a DVD drive's tray that doesn't open or eject ...
    ? 9:45
    https://www.youtube.com/watch?v=Kl1jB9MJXsE
    Jul 5, 2010 - Uploaded by lowendguru
    This video shows how to fix the tray of a CD or DVD drive when it does not eject ... I have a phillips cd-rom drive and it won't open, I checked the belt and its tight, so I .... Dvd Player Sticking Door Repair And Lens Cleaning.
    How To Fix A Broken DVD Player - YouTube
Dec 08, 2015 | Samsung Televison & Video
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
The cd player won<t open
Here is an easy fix to open your CD player all you need is a small paper clip. Open the paper clip up so its a straight wire. Make sure your computer is not on it needs to be turned off to do this. Look at the front of the CD player you will see a small pin hole opening. Push the straight end of the paper clip in that opening (hole) and push. Your drawer for your CD player should move forward enough for you to pull it open all the way. Once you remove the CD that is causing it to jam you should be ok again.
I hope this helps out if so please leave me some feed back.
Apr 02, 2011 | E-Machines eMachines Desktop PC
Open a jammed cd player
you have to take a screw driver and open it .the push it from the inside
Feb 01, 2010 | Onkyo DX-C390 6-Disc CD Changer
Closed player without stabilizer.
I dont know this player, but you can unscrew the top of the housing and look if you can see the CD tray. Just giving a shot.
regards,
Gerard
Jan 11, 2010 | Sony CDP-XB930 CD Player
There is a disc jammed in my cd player and the tray sometimes opens and closes but wont bring the disc out
Hi
Thanks for using FixYa. Locate your CD player’s manual Eject button. It is usually a small hole located underneath the CD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the CD and see if there is a problem with it. Most CD player drawers get stuck when a CD is warped or the label is starting to peel. If the CD is warped, discard it. If the label is peeling, remove the label.
To open the CD player top to remove the cd/CD manually--
  • Unplug the CD player and take the outer casing of the CD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending CD tray finally comes to rest within the CD player. It’s the part that holds the CD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
 Before you remove the CD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
 Use the opportunity while you have the outer casing off to clean the lens of your CD player.
 Never work on an electrical device that's still plugged in.
 Opening a CD player may negate the warranty. Read your warranty carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | GPX KC318S CD Player
Door not opening
Change the drive, the drive is known to have problems and you should be fine
May 24, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
E-Machines T3065 PC Desktop Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
