Hello, I am Sanjib Chatterjee. I have a old computer monitor. the problem is over the last 2 months or so it is blinking some time the situation great so disturbing for my eyes. please help me Thanking you Sanjib chatterjee
  • 85 Answers
There may be some problem in the monitor just make sure there is no low level power passing out in it
Posted on Aug 20, 2010
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
Apr 05, 2011 | Acer AL1916W 19" LCD Monitor
Gradually quit working For the last few months monitor would blank out on startup, but after warming up I could power it off and then on and then it would come to life. Now it won't start up at all and the...
The blinking power light indicates the power supply has failed. We have a step by step repair guide posted on our web site at: www.ccl-la.com The repair is easy to do but does require soldering. If you don't want to do the repair yourself we do offer a repair service for $30 plus return shipping. Check out the page and if you have any questions us the contact us link.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 24, 2009 | Samsung 225BW LCD Monitor
How do I replace my Intel Graphics Driver?
1. anti virus software
2. intel.com for driver
3. replace pc asap, it's kinda old
Jul 17, 2009 | Envision EN-985e Monitor
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 17, 2009 | LG Flatron 775FT 17" CRT Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
