Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I have three mr slim inside units...live in a very clean place, non-smoker, no pets, brand new renovation....problem is that the fans are constantly getting dirty. less than a month ago i had all three units taken down, thoroughly cleaned, drain hoses cleaned, etc. Put them back up and now they are accumulating what appears to be an abnormal amount of gunk on the fan blades. the filters are clean, the coils are clean, and the air intakes at the top of the unit are clean as well. anyone have any ideas on what could be causing this?
  • Mitsubishi Master
  • 17,130 Answers
Very strange indeed! The ffault is on anyway and there is a dirt that comes on to stick to the fan. So the logic is that the fan is bringing up the dust to the fan either from the inside of the unit or from the outside. if you are spot sure that there is no question of dirt in the enviuorment that can bring in dirt, even by static , we must focus once again to see if any of the insulation pads are wearing off and coming into in a slow way. Analyse the dirt on the fan, use a good magnifying glass to check , I hope this investigation will be the key to the fault. Please give me a feedback, credit if helpful. Good day
Posted on Aug 20, 2010
  • Donald DCruz
    Donald DCruz Aug 20, 2010
    Just a thought came to my mind, please check your carpets/drapes if heavily furnished as the fibres can statically get caught on with the aid of moisture from the unit. Regards
  • oldtec Oct 11, 2010
    There is an issue with the fan wheel itself. It depends on the age of the unit and if it is still under warranty. The blower wheel must be replaced with a "negatively charged" wheel. The repair must be performed by a qualifieds service technician, it is not for the faint of heart or inexperienced. This is not only dirt, it is a mold issue as well. I don't remember the dates but if the unit was built after a certain date it shouldn't be a problem. If it is under 2 years old it should be covered under warranty. Contact a servicing Mitsubishi dealer don't let some schmuck wreck your unit it is not an easy job but really must be done.
  • 3 Answers
You might have to run them on fan only for a half to 3/4s of an hour when you turn the a/c off
Posted on Aug 23, 2012
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan looks dirty but can not find directions on how to get to the fan to clean it!! Can you help.
mcdevito75 here, you could go to the website Mitsubishi Mr. Slim for directions?? maybe?. Most of the time the entire A/C unit has to come out of it"s Cover to get to the fan. Let an A/C shop handle the job, plus they check the entire A/C unit and give gauarantee.
Jun 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I need to clean the blower part of my Mr. Slim ( the cylinder )
mr slim has this cover. just unscrew the whole cover and you've got the visible blower. the power supply must be turned off so there is no electic shock or accident that other person may turn the a/c. then there is this cover of the fan with a lock so unlock it and you can clean it throughly with a cloth.....
Dec 04, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mold inside the home unit
You can use a spray bottle with 100% bleach in it to kill the mold. After spraying the gunk, you can put on some rubber gloves (those dishwashing ones are a good choice) and use some paper towels to wipe up as much of the mold as you can reach.
Spray more bleach on the parts you're cleaning to keep sanitizing the A/C unit and wipe everything dry. You should put all the stuff you used for cleaning it up (paper towels, gloves, etc.) into a plastic trash bag,
I'd also recommend that you do this when any small children and pets aren't in the room you've got the A/C in, and also wear a face mask to keep from breathing in anything that could cause a respritory ailment.
You can also use some Lysol disenfectant to give the whole unit a nice going over, once you're done, to be sure that you've killed any active mold spores. It might be good to give the unit a once-a-month cleaning to prevent the growth of mold in the future.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Inside fan not running in heat mode
i belive these units may have a cold air prevention sensor in them which wont allow fan ops until the coil reaches temp
Mar 04, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
Jul 12, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
479 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
