Question about Bosch Dryers
I have bosch dryer vented WTA3003GB. I need the wiring diagram for the connection because i accidentally disconnected the socket on behind the dryer when i check for the bearing. do you have any diagram?
  • 686 Answers
SOURCE: Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Posted on Apr 10, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
  • 32 Answers
SOURCE: how do you change the drive belt on a Bosch
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Posted on Dec 30, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer Bosch model number
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Daniel S
  • 4323 Answers
SOURCE: GE Dryer DHDSR46EE1WW TOOK DRYER APART
Hi
Please check the below wiring schematic---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Mar 13, 2011
The gas dryer works on timed dry but not any autosense cycles. The sensors were cleaned and 2 seperate service people checked it.
your post did not say if you have removed the vent tube and ran the dryer in any of the auto-sense cycles, I would do this first. If it runs normally with the vent disconnected then the vent is restricted. if you have already tried this then the reason it may not be working is that the wires(either blue or green) behind the sensor bars is/are disconnected/broken. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel, when you are in the diagnostic mode touch the two wires of the sensor together and if the light illuminates, it means the wiring to the sensor block and logic of the control is good. If the light doesn't illuminate, then either the control is bad or one of the blue wires is broken or not connected at the control. Hope this helped Tim
Mar 11, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
My dryer Bosch model number WTA3003GB/01 will not keep turning after being switched on. It works if the switch is pressed in but stops as soon as the switch is released.
heatman101
Jan 02, 2011 | Dryers
Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
    1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
    2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
    3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
    4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
    5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
Dec 24, 2010 | Dryers
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
What might be wrong if the dryer is not drying as fast as usual
Air flow. Check your lint filter. Disconnect the hose behind the dryer and check to see if you have airflow coming out of the drier. Hook it back up and check outside to make sure you have airflow at the external vent. Actually I would do these in reverse order.
Oct 28, 2010 | Bosch Nexxt 500 Dryer
Is it possible to re-configure the rear vent on a Bosch dryer
Most dryers have that option but not on the left side. You will need to cut a hole in the left side dryer housing. Then you will need to dis-assemble the back panel of the dryer and disconnect the vent pipe connection inside the dryer. Then run the moisture vent into the dryer housing from the left side opening and connect it to the venting system inside the dryer. You might not be able to put the opening in the same spot as the right side so you should do a visual inspection inside the dryer before making the opening to verify nothing is in the way.
Jan 22, 2010 | Bosch Dryers
Apr 10, 2009 | Dryers
Apr 09, 2009 | Bosch Dryers
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
55 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
