Question about Home
WHAT NUMBER TWICE THE PRODUCT OF 3 AND 2? - Home
  • 12,061 Answers
10 The answer is Ten.
Posted on Aug 20, 2010
How do I get this: Twice a number minus a second number is -1. Twice the second number added to three times the first number is 9. Find the two numbers.
Two equations:
x = first number
y = second number
2x - y = -1
y = 1 + 2x
2y + 3x = 9
2(1 + 2x) + 3x = 9
2 + 7x = 9
7x = 7
x = 1
y = 2(1) + 1 = 3
Oct 25, 2016 | Cars & Trucks
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Sanyo Dp53360 service manual
It was a little harder to find since you gave the wrong model number :)
Model number is DP55360. Here is the user's manual: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20(348A-)-38838316.pdf
Internet User's Guide: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20internet%20guide(358--)-34613941.pdf
Feb 12, 2012 | Sanyo Televison & Video
What is the answer of this problem? I am a four digit number. My ones is twice my tens. My hundreds is five less than my ones. My thousands place is the sum of my tens and hundreds. What number am i?
There are two possible answers to the above question, 4136 and 7348.
4136
My ones is twice my tens: The 6 (the ones) is twice as big as the 3 (the tens).
My hundreds is five less than my ones: 6 (the one) - 5 = 1
My thousands place is the sum of my tens and hundreds: 3 (the tens) + 1 (the hundreds) = 4
Jun 26, 2011 | Office Equipment & Supplies
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
3 or 4 mins into any game it bleeps twice and
needs a new power supply open it up take it out and look at the bottom for the product codes go online and buy a new one. ( i have the 1stgen and it cost me 51 dollors with shipping
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
I am trying to save my work on my transcend 4g usb stick but getting write protection error
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
I hope this helps
Oct 26, 2009 | Electronics - Others
Program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Jun 27, 2009 | Proscan Televison & Video
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
