Question about Bauknecht Dishwashers
Hello everybody, I hope that you gona a give me some tips for repairing my dishwasher mashine. A few days ago, the error F2 appears on my dishwasher machine (Baucknecht GSI 5894) I checked the pump for the waste water is ok. the tap water is not taking in,I checked the hoses they are ok as well I turned off and on and same time pressed the button reset and choosing the programm on the dishwasher few seconds trying to start and again apperas F2 . Hopefully someone can help me. Best regards Fehmi
    Genius:
  • 1,036 Answers
Possible the inlet valve has given up and is not allowing water in.
Also possible there is a slight leak enough to shut the water off (safety feature) - Check underneath for a float mechanism and any water there.
Posted on Aug 20, 2010
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
Dishwasher cycle stops and readout says F2
Hello, welcome to FixYa.
Based on your post, "Asko 1485 Dishwasher. It is showing a F2 code", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What the F2 means is the control has indicated a overfill.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump... (it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit and the illuminated F2 letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck. Please take a moment to rate my solution and your experience here at FixYa today.
Regards,
Macmarkus :)
Jul 16, 2011 | Asko D1776 Built-in Dishwasher
I have an Asko 1485 Dishwasher. It is showing a F2 code.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko D5152XXLS Dishwasher
My dishwasher keeps displaying "F2"
Welcome to FixYa.
Based on your post, the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
Good luck.
Regards,
Macmarkus :)
Mar 21, 2011 | Asko 24 in. D3350 Dishwasher
F2 and beeping sound when started
F2 indicates
WATER Leakage - Water is in drip tray
Floater switch (water leakege detector switch) detects water leakage,
then draining pump is switched on for fixed time or until water indicator reports
that mashine is empty depending on model
remember to unplug it from power if any repair is done
Best regards and good luck
Oct 03, 2009 | Whirlpool Dishwashers
Lens Cover Error
Download the document "nikon s5 s6 lens cover error repair.doc" from www.esnips.com
Or go to the link
http://www.esnips.com/web/papputatiyasStuff
Jun 05, 2008 | Nikon COOLPIX S5 Digital Camera
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
May 28, 2007 | Asko 1595 Dishwasher
Dishwashers Logo
752 people viewed this question
Top Bauknecht Dishwashers Experts
ray gallant
michael mcdonald
Level 1 Expert
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
