Airtron programmable thermostat is not displaying anything and the air conditioner is not coming on. How do i find out it its batteries or something else.
  • Anonymous Jun 06, 2008
    Same thing happening. There are no instructions of how to open it up to see if any wires ar loose, nothing.
  • Bartholemew Nov 23, 2008
    I'm having a similar problem with my 4 year-old AirTron (by Honeywell) wall mounted unit. I have two AC\/heater units (upstairs and down stairs). I have been using my heater, intermittently, for 2 months. During that time they were working fine. Just last week and overnight, the display window on the downstaris unit no longer displays anything and the heater went off but the AC has turn on without shutting off. I've turned the AirTron switch to "off" yet the unit did not turn off. The fan switch is on auto. After 2 hours of trying different things without any changes, I turned the circuit breaker off to keep the AC from blowing cold air continously. Any ideas for repair other than calling a technician just yet?
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Posted on Jun 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
Posted on May 25, 2009
  • 358 Answers
SOURCE: Have a Bryant AC/Heat pump. Model# 661CJ030-A.
If the compresor doesn't start ,try to put a booster to the capacitor , also check for burned wires at the compresor terminals , if still won't run it is burned out or stuck.
Posted on Aug 20, 2009
  • 52 Answers
SOURCE: Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Posted on Mar 07, 2010
Testimonial: "When I hold the thermostat in my hand the digital temperature goes up. Is that proof that it is working?"
What do i do. Im getting 230 volts to unit. Not getting the power light to come on .. the display doesnot appear.
Not sure what power light you are talking about, or what type of HVAC system you have. Though you say that the display does not appear. Is the display on a programmable thermostat? If so, most programmable thermostats use an internal battery for power and not the low voltage side of the air handler. So check your thermostat to see if it does take a battery(s) and try changing them.
Apr 27, 2014 | Heating & Cooling
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
How do i set an apartment honeywell thermostat ? it is programmable but i cannot figure out how to set it at a comfortable temp. i must have done something wrong because it continues to come on even...
remove the batteries and turn beakers off to system air handler or furnace. Wait till screen clears so that T-stat will reset. Then re-install batteries and turn breakers to on.
Apr 29, 2011 | Honeywell Heating & Cooling
Carrier programmable thermostat
if it takes batterys pop some in and see if not it gets the power from the indoor unit
Apr 06, 2010 | Heating & Cooling
Problem with my Airtron Thermostat
Two things, first go up to the heater and check the fuse inside the heater, looks like a car fuse. If that is not popped, then go outside to your AC unit and pull out the emergency disconnect. Check those fuses with a multimeter. IF you do not get anything replace those fuses, It has nothing at all to do with your thermostat.
Feb 09, 2009 | Honeywell Programmable Thermostat Heater
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
863 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
