Question about Kenmore Dryers
I have a Kenmore Elite digital dryer, manufactured in 2002, and it will run for awhile but then it stops and sets itself to a certain dry time/settings and wont do anything else. When I press stop, it just goes right back to those settings but will no longer dry. Also, when it does this, it continuously beeps. Both my washer & dryer say PF sometimes....
I have a newer model of what I believe is the same dryer. I'm not sure if the layout is the same on yours as it is on mine.
I had the same problem, first the problem stems from user error -- there's a reason they say to empty the lint trap after every use. I know I've been remiss in emptying it thus my beeping bonanza.
Second -- THE FIX -- in the lint trap area (this is described based on my 2007/08 model) there are screws that allow you to remove the lint trap censor cover, unscrew, you'll see it's connected to wiring, there are 2 electrical connections, these slide on and off, gently pull and each will slide off, clean the connectors. By disconnecting to clean, which is the basis of the problem, the electric function resets (as far as I know), the beeping stops and you're good to go! Good luck.
Posted on Sep 09, 2010
Dryer element where is located
Your Thermal Fuse probably blew, get a Digital Volt Meter from Harbor Freight $5.00, locate the Thermal Fuse and check the OHM's to verify it s the fuse, replace it needed.
Sep 15, 2014 | Kenmore Elite HE4 Electric Dryer
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
How do I stop fluff cycles on kenmore elite dryer
There are two ways this can happen:
1. You set the timer to a cycle that activates this option
2. (If equipped) Turn the selector knob off on the control panel that you can activate this feature with. Every manufacturer calls it something different.
May 12, 2012 | Kenmore Elite Oasis 7808 Gas Dryer
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Samsung front load dryer had a burning smell-it stopped drying by itself. Dryer power will come on but will not run when start button is pressed. Do you think my dryer can be repaired? It is only a 1 1/2...
ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
Apr 16, 2009 | Kenmore Elite HE4 Electric Dryer
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
