Question about EliteGroup P4VMM2 Motherboard
WIRING CONNECTION - EliteGroup P4VMM2 Motherboard
    President:
  • 2,351 Answers
You'll need to download the manual for you're ECS P4VMM2, MB.
If you no longer have it.
Left click on the link provided by ECS below to open;
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=P4VMM2
There are many version for the P4VMM2 MB. Look closely on you're MB for the correct revision. There are slight differences between each revision. You will also need to download Adobe reader to view the manual. If you do not have Adobe reader installed click on the link to download and install Adobe. (Adobe is free).
http://www.adobe.com/products/reader/
The most important connections start on page 11 to page 14. For front panel wire connections. Hard disk drive LED, Power LED, Reset LED ECT, keep in mind which wire color is ground & which wire color is positive. You'll find 1 common color for each jumper. This common colored wire will be used for ground. The other colored wires will be used as positive. (Execpt internal speaker). Internal speakers normally use the color red for positive and black for negative.
Just follow the manual and you'll find it is not very tough.
If you get confused or lost feel free to post questions.
Cheers'
Mike
Posted on Aug 20, 2010
Wiring details for alpine3215
Wiring connection diagram. For Alpine 3215 7-band graphic equalizer with 4-amps. have custom scanned this item for those folks that don't have a need for the full service manual and just need a simple connection diagram. Includes wiring connection diagram and pin-outs of the din as well as output block connectors.
Sep 28, 2016 | Car Audio & Video
Why does my honda 420 FI light flash 9 times
Check your bike with it parked on the side stand. Count how many times the F1 light flashes. There are two types of flash that it gives off... a long one and a short one! A long flash = 10 short flashes.
So you may get 2 x long flashes and 5 x short flashes = 25 flashes in total.
The codes for Honda ST1300 are as follows. I know yours is a different model but I would have thought they would all be the same across the Honda range.
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
Aug 18, 2015 | Honda Motorcycles
Wiring on my timer on white knight tumble dryer 44as asburnt what can cause this
Usually a burnt connection is caused by too much amperage or a loose connection
Aug 31, 2014 | Dryers
Error code LS
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Mar 26, 2014 | Precor Exercise & Fitness
Precor L5 error
Corrective Action
Dec 19, 2013 | Precor C954i Commercial Treadmill
Nissan pulsar electrical harness between body and door connecting to door
you should be able to loosen screw to split the connection, if i think this is the type you have then the clips are used to keep bolt from falling out, you should be able to loosen and pull connector apart
Dec 01, 2013 | Cars & Trucks
Precor treadmill error L5
Corrective Action
Feb 25, 2012 | Precor 935 Premium Series Treadmill
Got a c11 and a c12 on my suzuki tl1000r what does it mean
c11 Camshaft position sensor or circuit malfunction The signal does not reach to ECM for more than 2 sec. after receiving the starter signal. The CMP sensor wiring and mechanical parts. (CMP sensor, rear intake cam pin, wiring/coupler connection) c12 Crankshaft position sensor or circuit malfunction The signal does not reach to ECM for more than 2 sec. after receiving the starter signal. The CKP sensor wiring and mechanical parts.(CKP sensor, wiring/coupler connection)
May 20, 2010 | 1999 Suzuki TL 1000 R
EliteGroup P4VMM2 Motherboard Logo
204 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
