Question about Fagor 18 in. LVC-21W Free-Standing Dishwasher
Glasses are coming out of the machine still covered in spots and not clean looking
    Genius:
  • 1,036 Answers
Turn rinse-aid up to maximum for 2 washes, and refill your salt container. Reset the rinse-aid gradually back to your old setting during the next few cycles untill you get the right (economical)setting.
Posted on Aug 20, 2010
Black spot of bhotograph in my samsung scx 3200G printer. so what i do this problem?
Dear
Please clean the platen cover(white sheet on the cover. clean the platen glass with lens cleaner/colin etc. with cotton cloth and dry with rubbing. see for any spot on the glass.
If the cart. refilled, check any spot on opc drum clean the drum,pcr roller, etc.if possible replace the drum. if you are not refilling then may replace with a new cart.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do I remove white streak from copy when i use my 3015?
Most common cause of this issue is low toner. Best solution is to remove the toner cartridge and while keeping it mostly level, shake it from side to side to level out the toner. Then re-install and test. If this fixes your issue then just be aware that the toner cartridge is starting to get low on toner.
Now if the white streak is very fine and the above procedure does not work then it is most likely something stuck to the scanner glass. To test for this print out a report from the operation panel or if you have the machine connected to a PC print something from there. Are your print outs ok? If so it means that it is definately something on the scanner glass. To locate it and clean it just make a copy of something. Now take that copy with the blank line on it and place it in the feeder just as you did with the original. now wherever the blank streak is lined up on the machine is where the spot is going to be on the scanner glass. Just open the cover where the documents go in and look for the strip of glass that runs from side to side. Your copy passes over this glass when it is scanned. Where the blank line hits this glass is where the trouble spot is. Just clean the glass with a cloth that has some glass cleaner sprayed on it. This should resolve the problem.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Aug 23, 2010 | HP Office Equipment & Supplies
When I fax something out the recipient gets lines through it ... I think it might need a cleaning ... What are your thoughts?
you are right lift cover where your originals feed in you will see a peice of glass it most likely has white out on it or ink spots clean glass with alcohol on rag or soft cloth do not soak it only dampen the cloth turn fax power off before cleaning
May 21, 2010 | Office Equipment & Supplies
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Copy and fax problem
Open the document feed portion of the machine, this should expose the exposure glass. Clean this glass with a good quality glass cleaner and soft paper towel. But sure to check closelt for any spots or streaks.
Hope this is of some help.
Ed
May 12, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine problem
- Did you try to change the cartridge?
- Try to check the glass if they have some spot then performed cleaning if they dust.
- Check if they have dust of your paper roller?
Sep 12, 2008 | Brother IntelliFAX 4100 Laser Fax
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Dishwashers Logo
140 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
