Question about InFocus ScreenPlay 61" Rear Projection HDTV
Question about lamp...
How Do I Know If It Is The Lamp That Is Out Or Do I Just Have To Guess?
    Genius:
  • 2,920 Answers
You need to have someone from a shop tell you for sure otherwise you could be buying parts you dont need
Posted on Nov 03, 2008
70 rear projection jvc no picture and bulb ok
Hello, remove the lamp and make sure it didn't go bad. If it's ok the a color wheel or fan would be my next guess, but check the lamp first, I see cheaper lamps that don't match up correctly fail early. let me know what you find...tks
Feb 24, 2015 | JVC HD-70FH96 70" Rear Projection HDTV
Tv powers on intermittently when the power button is pushed. When it does the tv has sound but no picture.
Hello, first off the set was last made in 2006, so it's 8 years old. Have you checked to see if the lamp is bad? Disregard "Houndog101"'s remarks, they are for an older crt projection tv. If the lamp is ok, it may be the color wheel has failed, a power supply or a bad ballast board, but my first guess would be the lamp part number 915P027010. Let me know what you find on the lamp.....tks
Oct 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
I installed new lamp comes on then goes off and I hear a buzzing sound. Could it be that it's not installed properly for get light to come on. I had to use different screws because the new lamp didn't
How do you know the solution is "simple"? No always is simple. Bussing is high voltage missing. Like is bad conection to the lamp. Check conections of it.There is some bad about the conections of lamp. I guess.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
Why does my brake lights/turn signals work but my running lights don't work in the rear?
I won't insult you by asking if you've changed the bulbs in the rear sockets with the proper GM-numbered bulbs (no "Made in China" junk substitutes).
Identify the tail-lamp wire from the tail-lamp sockets, and trace it back to fuse block. Truck this age, my guess is you may have rat/squirrel damage to a wire. Don't know why, but varmints love to chew wires. IF the parking lamps up front work, it isn't a fuse, is why I suggest looking for a broken wire--chances are poor that you have 2 bad lamp sockets in rear.
May 29, 2014 | 1988 Chevrolet C1500
Green light is on steady and the screen is off
Lamp cannot be tested like a regular bulb--if set shut down you should have some kind of blinking light up front---lamp possible but not likely as it should trigger the lamp light.
Either guess or call an expert to examine it.
Apr 29, 2012 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
55PL9223 Questions about Lamp
lamp could run 200-325 would be my guess. check out ebay for one and get an extra if its a good price. lamps are common for going out.
Oct 31, 2007 | Philips 55PL9223 55" Rear Projection...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
59 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
