Question about Zebra TLP 2844 Label Printer
The Zebra Printer TLP 2844 keep on turning the Feed button red even after calibrating it. The settings are similar to the other printers that we have distributed countrywide. Any solution?
    Scholar:
  • 62 Answers
Check your ribbon, it may be coming off drive sprockets. Easiest way is to calibrate printer with ribbon out.
Posted on Aug 27, 2010
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My zebra TLP2844Z can not print because after fiew moments turn on the printer the light button becomes red. How to solv that?
A constant red light usually means the printer is out of ribbon or labels. It may just not recognize the size of the label so try a manual calibration to set the size.
1. turn the printer off
2. press and hold down the FEED button while turning on the printer
3. Keep holding down on FEED until the led flashed once, then let go
4. The printer will do an auto-calibration on the label.
When it's done, pressing FEED should advance 1 label. It's then ready to go.
Hope that helps !
Mar 23, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Red line indicate
there are many possibility,
1. wrong ribbon installation , make sure there's nothing wrong, if need u may change the ribbon sensor
2. label not detected, change the label sensor
3. Printer need calibrate, turn off the printer, press and hold the feed button then turn on the printer after it flashes a red light , let go the button, it will do a manual calibrate, wait until it finished, it should be back to normal
Aug 16, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Oct 20, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 Label Printer Logo
256 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
