I have a big screen toshiba tv, it's an older model and it is showing double picture, kinda like 3D, wondering what the problem would be. Not sure of the year or anything like that as i don't know where to find it. any help would be great. Thanks
This is a failure of the convergence circuit. There will be 2 or 3 sometimes, large black IC's labeled STK... (something.. generally 392-110,or 120, or 150) These need replaced, check for open fuses, could be glass type or pico fuses, also check all resistors around the IC's for burn marks, these must be replaced with EXACT replacement parts.
Posted on Nov 16, 2010
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
I have a big screen samsung it plays red and green and the imaged are doubled looks like 3d any ideas
Your question shows its Samsung rear projection TV that has 3 tubes to project picture.
Symptom shows TV got problem in convergence board that will be replaced.
Model number or TV would help me to provide you more info.
Thanks.
Jan 15, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
The screen broke
Well it's hard to find the screen separately anyway you can contact to Toshiba and ask them for the screen, Follow the below link to contact Toshiba  -
 http://www.toshiba.com/tai/
Good Luck!!
Thanks
Dec 12, 2009 | Toshiba REGZA 52RV530U LCD TV
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
Aug 26, 2009 | Televison & Video
My TV is showing a double picture
If the picture looks like a 3D one, the problem is a convergence issue. This can be as simple as poor connections at the pins of the convergence ICs or defective ICs. If you can solder you can probably fix this yourself. Please note that there are potentially dangerous high voltages inside the set even when unplugged.
If you wish to attempt the repair, please update this and I will provide additional details and instructions.
Dan
Mar 02, 2009 | Toshiba 43HX71 43" Rear Projection...
Philips magnavox big screen tv that has sound but no picture
the picture driver has gone bad, look on ebay for one,make sure it looks just like the one you have, or it could be the verisitor has gone bad it's a kool fix
Nov 21, 2017 | Philips Televison & Video
My alignment is off on the picture
If you can reply to this same post and Include your model number of your Hitachi I can assist you with what you will need to get the set operating properly again, as its your Convergence amp Ics Its a very easy an inexspensive repair that you can do yourself and save about 400.00
Jun 19, 2008 | Sony KP-41T65 41" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
