Question about Konica Office Equipment & Supplies
Sir, i am using Konica Minolta C252. I am getting error message C-2553. If i opened the front door and closed then the error message will go, but again it will come after some copies. What is the problem sir, please help me.
  • Konica Master
  • 6,696 Answers
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
Posted on Jan 17, 2015
SOURCE: konica minolta bizhub C252 printer Problem
You should be able to get Konica Direct to take care of it.
Posted on Jan 31, 2008
Geekinator
  • 183 Answers
SOURCE: error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 16, 2008
  • 47 Answers
SOURCE: Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Posted on Jan 06, 2009
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Posted on Apr 02, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
My konica minolta printer is show error code 4501
sir, Open close front door. to reset. if code comes back your Print head is bad. The print head houses the LASER for each drum. ITS ONE UNIT
Mar 13, 2017 | Konica Minolta Office Equipment & Supplies
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
How to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
May 23, 2015 | Konica Minolta C451
Printer Ink Leaking
I suggest you contact Konica Minolta bizhub printer support technician, Because may be dust available in printer so not access full cartridge. So first full servicing and then you used or change cartridge in printer.
Thanks,
Sep 09, 2014 | Konica Minolta bizhub C250 All-In-One...
How I can reset counetr imaging unit bizhub c250?
You do not reset purchase new image units, the codes reset via open close the front door
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c252 error c-5351
Feb 22, 2013 | Konica Minolta bizhub Office Equipment &...
We have a Konica 7033 and has the message Front door is open. Everything is closed.
Hello sir; Check the door switch actuator is broken ? or out of possition need to adjust it.
Oct 09, 2009 | Konica Minolta Office Equipment & Supplies
Error H2 after copying on Minolta Di151
Hello sir ; Here is the way to reset ,just opening and closing the lower front door.
Aug 18, 2009 | Konica Minolta Office Equipment & Supplies
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
285 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
