HP NB199UA Pavilion Notebook Logo
Posted on Aug 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp pavillion dv4-1220us is not showing any display..just my caps lock and num lock key r blinking. and my shortcut keys in the pads are active..with sound key on mute state and wireless key on off mode..
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1238
Points
I cant say what to do .. But please dont give to service to ETECHIES .they are the worst service providers
  • Anonymous Apr 20, 2013
mrmb2003
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on May 10, 2012
mrmb2003
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1319
Points
How many times does the capslock and numlock blink? I have a Hp pavilion dv4-1225dx and it did this. It's either the processor or motherboard. For awhile I thought it was the cable for the monitor but the code said it was the processor, so I bought a used working one on ebay. It still acted up so, since mine was out of warranty, my husband put my motherboard in the oven and well, here I am typing to you. The sodering job HP did was not very well, so the heat from the oven sodered it back. I'm not saying bake it or anything because there is a 90% chance the motherboard is fine and will die doing so. I would have someone look at it and look up the blinks online and probably buy a processor. Good luck!
Anonymous
Level 2:
Novelist:
  • Expert 256 Answers
  • Posted on Aug 11, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
256
Questions
Helped
512884
Points
332
Due to the problems in the inverter or due to the troubles in the cable connection usually screen flickering happens in the display of HP Laptop. As the inverters are responsible to supply power to the back-lit of the screen, any problem in the inverter would create troubles. By replacing your inverter and by checking the connections of the cable in your HP laptop, this problem could be easily resolved.
Get more information to fix HP laptop no display problem. hope this information helps you.
Anonymous
Level 2:
Sergeant:
  • Expert 238 Answers
  • Posted on Aug 20, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
238
Questions
0
Helped
43265
Points
570
  1. Check ur powercord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
4helpful
3answers
When laptop hp compaq 6735b (made 2008) year the solder ball failure year!!!
the number of times the num lock (1) and caps lock (A) blink will indicate where the failure is, but I would try removing and re-seating the RAM as a first fix!
1helpful
2answers
How to unlock laptop key pads in hp pavillion
Hi, if you want to switch numeric keys on or off, you can do so by pressing Fn + Num (located above Backspace) simultaneously.
If this solved your problem, please leave a positive comment for me.
6helpful
2answers
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
Hp compaq powering and nog display what do i do to
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
18helpful
4answers
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
1helpful
3answers
The multimedia keys in my hp pavillion keyboard do not function
Go to the following link, enter your model number (ie dv9074cl) then go to driver downloads and download the driver for quick launch buttons.
1helpful
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
12helpful
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
