Question about Logitech Webcam
I am not able to hook up to the logitech and neither is the person I usually talk to. Is there something going on with the system?
  • Logitech Master
  • 2,992 Answers
Logitech Software Installation
Visit the Logitech website and browse the photo gallery for your model and click on the photo to navigate to the support page.
Note - Older models on page 2 - look for the link at the bottom right of page 1 and click on it "Still can't find your product?"
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
In addition to the Logitech installer you will need to download Microsoft DirectX 9 or later to support your webcam
Procedure
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Logitech
Run the installer and choose your options during the installation - You may not want Logitech Chat but the Desktop icon for the webcam toolbar is a must.
Connect your webcam when prompted.
Configure to Yahoo Messenger
Plug in your webcam and visit this site - Hit 'Allow' in the top window and check your cam in the left hand panel.
Do not proceed if the camera fails to work here, but concentrate on your webcam software / drivers
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger 10.
COMPATIBILITY WITH YAHOO MESSENGER
You MUST use Internet Explorer to visit this page, with your webcam plugged in, to check compatibility and automatically download the latest webcam control. Make sure your webcam broadcasts on this page before moving on
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam Broadcast > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
AUDIO
Open Video and Voice - run through your default equipment and make a test call - click OK
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your default equipment selections and who you will allow to view you > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'.
Messenger 10:- > Actions > More Actions > invite to view my webcam. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( +1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts may need to configure their connection the same as INTERNET CONNECTION above (Ignoring webcam connected) if they get a "webcam not connected" message
Sometimes you may have to broadcast the 'small image' option from the 'Webcam' menu on the top of your image frames. This happens when one of you is down on resources -its like sending a large photo by email - its quicker if you cut the size down
you can zoom up to 200% from the same menu when the webcam picture comes through
Use the 'Always on top' option from the 'webcam' menu - or your image will disappear under the message window when you type a message
Configure to Windows Live Messenger
Set your webcam mic (if it has one) as default
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel and set the default mic from there - make sure its plugged in.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Configure to Skype
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
Set your webcam mic as default ( if it has a built in mic
Plug in the webcam
TEST SPEAKERS
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
Restart computer
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Posted on Aug 20, 2010
I have a quickcam for notebooks i ran the instillation cd and the camera is not coming on i have windows 7
try uninstalling the software, then reboot, after you reboot, try hooking up just the camera without the software and see if it works, you can also try going to the Logitech website and looking for updated drivers for windows 7, you can also usually use windows vista drivers
Nov 18, 2009 | Logitech QuickCam for Notebooks Pro...
Using skype, I can see other person but they can't see me
This is sometimes what happens when you have the Logitech camera software open at the same time you have your chat software open. I'm guessing that you are trying to chat using Yahoo Messenger or something like that. If you turn off your Logitech camera software, it should work within Yahoo or other software. The problem is that your camera cannot display two video chat windows--only one at a time and most people dont' know that and leave the Logitech software running in the background which prevents the camera from showing a picture to others. If this is not the problem, check the camera on another computer to ensure it works fine with the same software when chatting to someone. If it works on the other computer perfectly, then go to your "hardware acceleration" and move the slider all the way to the left. This will fix the problem quite possibly. If you don't know where that is, just type it into your Windows help and it will show you.
Sep 12, 2009 | Logitech Webcam
I can see a person to whom I am talking, bat he or
?? I just installed a new logitech 1.3 megapixel camera. The problem my picture is not going out. No problem for me to bring it up. Incoming
picture comes in O.K. I'm trying to use this on Skype. When I ask it to
send video it starts to load and then stops. Can you help me. lwafbaker@sbcglobal.net
Thank you, lwb
Feb 26, 2009 | Logitech QuickCam Pro 5000 Webcam
Logitech ClearChat Pro head set
Go to your play control (double-click the speaker icon in the system tray) and mute the mic on the "Play" control to avoid feedback.
Jan 15, 2009 | Logitech ClearChat Pro USB Headset
Cant talk on my ps3
ya you gota go the, assories, the system sounds, or something like that. You need to make the Logtec your mic and headset. Then it will just work, open mic no button to push on COD4. I think it may be adjust sound levels, or something to do with sounds under the assories settings.
May 30, 2008 | Sony Playstation 3 (PS3) Console
Installing a logitech
Go to http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=gb,en
you can download drivers from the Logitech support centre. You'll need to look on the webcam (or packaging if you have it) and find the model number. Select your product from the drop-down boxes and download the relevant software onto the pc. If you then unplug the webcam from the pc, and plug it back in again the software will begin to install, you will have to click next a few times whilst it is installing.
Feb 20, 2008 | Logitech QuickCam for Notebooks Pro...
I cant install my new Logitech Quickcam Communicate STX
well first get windows sp2 here:
http://www.microsoft.com/windowsxp/downloads/default.mspx?wt_svl=20396a&mg_id=20396b
speaker problem go here:
http://www.wikihow.com/Fix-Computer-Speakers
Finance problem go here:
ok just dump him.
Dec 08, 2007 | Logitech QuickCam Communicate STX Personal...
Webcam
yes you need to use yahoo or msn and then chat with that person and if you want to see them on cam you invite them to view webcam.
Dec 06, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech Webcam Logo
124 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
