Question about Uniden Cordless Phone
While talking the phone drops out and the message "Handset out of range" shows and then "Searching".We can not receive or ring out for hours. Prior to this it sounds like you are talking under water.
  • 77 Answers
I would advise you to check the length allowed to use the cordless phones, as some don't allow more than 1 meter away from the base, hence you need to use it within range. If this doesn't solve your problem, then you should take it back to where you bought it and have it looked at.
Posted on Aug 20, 2010
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
My handset is display only searching, I cannot make or recieve calls & it is just flashing 88
when I press talk I get connectin9..handset out of range..searcgin9
when I press end I get Searching
Jan 30, 2013 | Uniden DECT 6.0 Cordless Phone
I have the D1660 series phone and it keeps saying searching? And that the handset is out of range? what do I do?
I had the same problem, I removed the battery from the handset, placed it back then I remounted it on the base. it said welcome and after 2 to 3 mins, it started showing the signal icon on the left top corner of the display. I picked it up from the base, pressed talk button it started working. Good luck try it out, it would work.
Sep 10, 2011 | Uniden D1660 Cordless Phone
Why is handset reading out of range? OR searching?
THAT HAPPENS WHEN YOU DROP THE PHONE TOO MUCH.
THE SOLUTION IS TO TURN OF THE BASE FOR 2 MINUTES.
THEN REMOVE ALL THE PHONE BATTERIES. ALL OF THEM
WAIT FOR MINUTES,
PUT THE BASE BACK FIRST, PUT ALL OF THE PHONES BATTERY BACK
PRESS THE RED BUTTON, YOU WILL SEE THE "OUT OF RANGE RANGE" MESSAGE AGAIN.
IGNORE IT AND PRESS THE GREEN BUTTON. HERE YOU GO.
MAKE SURE TO CHARGE IT AFTER THIS.
PLEASE RATE IF THIS SOLVED YOUR PROBLEM
Apr 12, 2011 | Uniden DECT 6.0 Cordless Phone ID
HaveBinatone Symphony 3325 triple. screen shows 1 new call. cannot listen to call or clear it cannot receive or send calls. can you find me the instructions to clear this please
Showing 1 New Call would mean you need to check the Caller Display Record by pressing the arrow pointing up marked "Calls". This is not related to not being able to make/receive calls. If the phone is ringing and displaying "Handset 1" then check line, if it says "searching" then you will need to register handset. Call 0845 345 9677 for more help.
Feb 24, 2011 | Cell Phones
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
"searching" message
the handset is defective, the receiver has failed, no signal triggers the message.
Feb 11, 2009 | Uniden Cordless Phone
Searching for base and battery loses power too soon
Have the batteries been changed since the system was purchased... 4 years is a fairly good usage for batteries in that type of use.
Good news you should have no trouble buying replacement batteries... even walmart has them. Open the back of one of the phones... the battery has a small plug.. pull that out and you will see the part number... about 25 dollars each battery pack... cheaper if you are in the states.
One note tho... when you replace the battery pack you need to charge it for at least 12 hours prior to the first usage 24 hours even better.
Robert
Dec 19, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phone handset display continuously showing
Buy a new phone but not a VTECH piece of crap. Thier support sucks and you never talk to a person. It is all automatted.
Dec 13, 2007 | Lands Phones
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
