My sony wega kf-50we610 unlike every one else i have no problems with set turning on my problem is i cant watch anything do to the picture being distorted scrambled like i can see the menu options and memory card screen fine very clear but the rest of the inputs as well as the analog and s video are distorted as if the video was in pal format instead of ntsc all distorted and jumpy with horizontal lines each input has a different color set of lines no ghost or anything like that i know it is not the optical block im think possibly the video board
  • lavergne337 Aug 20, 2010
    i am some what familar with problem shooting thats how i was able to narrow it down to video board i wanted a second guess and thanks for that now i have another question i am not that good at this stuff you mentioned a PIN amp and hstat and y amp i have no idea what these are whould it be easier just to change the video board or can you explain these more thanks
  • lavergne337 Aug 23, 2010
    im sorry herehttp://i37.tinypic.com/jhfv9f.jpghttp://i35.tinypic.com/2ex7znp.jpghttp://i34.tinypic.com/2h740gk.jpg
  • Televison & ... Master
  • 17,130 Answers
It looks like the vidoe board but the fault can be also a distortion in the horizontal / vertical section. So check the PIN amp and related sections. What must be looked is of the HSTAT can be off set.
Deguass the set well to confirm if there is any possibility of a distortion of picture by a severe magnetic field.
Since there can many problems associated with a distorted picture but you can try and see these possibilites other than the Y amp processing. Hope my suggestions helps.
Posted on Aug 20, 2010
  • 3 more comments
  • Donald DCruz
    Donald DCruz Aug 20, 2010
    The PIN amp is the horizontal freq. correction for the picture frame.. trapezoid...horizontal width.
    the HSTAT is found on Sony TV's only in the HT output Anode voltage. find this one on the crt base orr positioned on the crt metal screen.
    i figured out how to get into the service menu this is the only code i get 6: b ovp 1
    sorry it is 6 : b ovp 1
  • Donald DCruz
    Donald DCruz Aug 21, 2010
    Sorry the model I commented does not have the correction through the menu. In this case try to press and hold menu/power while switching power on, if it goes to menu then try to correct the horz. data. Hope this work.else take clarification.
    the code you gave me didn't work but i figured out how to get into service menu i restored to factory settings i did no good but i forgot to tell you that it used to take thirty minutes to come on i disconnected everything and reconnected and it turns on right away now also i noticed yesterday that if i let it run a while the jumpiness mellows down probably 75 % but lines do not fade at all here are a links to some pics of my TV and what it looks like i didn't find anyone with this model in any forum that had similar problems as mine and learned that 6 : b plus ovp 1 means over voltage proection but would could be cuasing this lamp only has 3000 hours it is rated for 6000 hweres links to pics
    [IMGhttp://i37.tinypic.com/jhfv9f.jpg[/IMG]
    [IMGhttp://i35.tinypic.com/2ex7znp.jpg[/IMG]
    [IMGhttp://i34.tinypic.com/2h740gk.jpg[/IMG]
Brightness problems with sony kf-50we610
This is typical for a set that uses a lamp, as the lamp needs to warm up.
If it is taking longer than normal to brighten up, then your lamp could just be aging and needs replaced.
Jun 19, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kf-50we610 turns on and off
If picture is a bit darker than it used to be replace the lamp--some of these if lamp dims set will turn on and off.
Jun 14, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Dim and reddish picture SONY lcd kf-50we610
Light Engine/optical block
Encompass Parts Distrubtion 1-800-638-3328
Apr 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Kf-50we610. will not turn on , you hear a buzzing
U need to change its power ic..
Plz dont forget to rate me
Sep 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
Electro Med Services...
