Question about Lexmark C532n Color Laser Printer
920.08 service engine self test error - Lexmark C532n Color Laser Printer
  • f_githua Oct 08, 2010
    the problem is persistence. give me a solution
    Problem Solver:
  • 10 Answers
Try turning the printer off and leaving it off for a few seconds. If the error does not return on power up, it may have simply been an isolated incident. Continue using the printer, but keep an eye on it for the next week or two. If the error still shows, here is the detail solution: http://www.marketpoint.com/article.cfm?id=119&bhcp=1
Posted on Aug 20, 2010
3 Suggested Answers
  • 241 Answers
SOURCE: Service Engine Self Test
A bad fuser connection can cause 920.8 service error. I would advise to check and reseat the fusing unit.
Steps
1. Turn off the unit.
2. Open the top cover.
3. Loosen the green thumbscrews on the fuser. (caution the fuser can be hot)
4. Pull the fuser straight up and out of the unit using handles on either end ot the fuser. (darker grey plastic)
5. Examine fuser for paper stuck in the rollers or sensors. Also check the electric contacts for damage.
6. Reseat the fuser and tighten the thumbsrews.
Posted on Jul 22, 2010
SOURCE: printer is hungup on self test
920.08—POST (power on self test) error service check (Sub Code .08 (Exit sensor not connected.))
Check the Exit Sensor for Damage or dust.
Check DC auto-connects on both the fuser and the printer for damage.
If connector is damaged on fuser, replace fuser. If the cable connectors is damaged, replace the JFUSER1 cable.
Check resistance of the fuser, lamp, thermofuse, thermistor
Most Cases you will need to replace the Fuser.
Posted on Apr 17, 2009
Dash lights on my 2010 venza won't go off when driving on dash
are there some that do go off, ????
the ENGINE light glows when there are engines problems
you scan the PCM and it reports errors, YOU HAVE ERRORs, scan it.
the brakes come on, if engine stalls. or RPM on engine falls real low
about 300 RPM the engine can stall, (engine problems) and when it does that the dash goes to self test of dash lamps.
turn key, no start, see all those lamps doing there self test? bingo that.
if engine RPM are normal and the brake lamp comes on,, all this is in the lost operators guide int he glove box.
Brakes failure or hand brake is left on, it says that clearly and is true.
Jan 30, 2014 | 2010 Toyota Venza
All key pad works, except to clean oven. It double beep sound and nothing happens.
Hi Carol.
First make sure that you are performing clean procedure correctly. If you press both bake and broil and then self clean, then instead of self clean the oven will go in child lock beeping twice. Two beeps may also be result of incorrect temp calibration. Perform calibration as suggested in the extract from service manual below:
Before starting the self clean cycle the electronic control (ERC) performs checkout of door latch and temperature sensor, lock motor is activated and both relay for bake and broil start the cleaning cycle. If one of the conditions is not met the electronic control will beep and you may get an error code.
Make sure that both bake and broil are working. If one of the two functions is not working, then one of the relays in the power board is likely faulty: If the oven is not heating at all , then problem is usually the oven sensor.
If the rest is working the problem can be the door lock motor. The relay board and control module may also be causing the problem. The oven must be tested.
This GE range is mostly electronic. Testing is mostly done following the diagnostic procedures suggested in the technical repair manual.
The first procedure is error code reading (user level). This consists in reading the error codes stored in the oven electronic control (AKA ERC).
Here an extract from service manual showing the procedure:
The procedure can be found in the Service Manual at the bottom of this document. Check page 19 of the service manual.at the bottom of this document. When performing the test look for error FF and F2, which respectively mean door latch and oven sensor problem. (codes at page 24 of service manual.
After the error code test, test individually door latch, sensor and lock motor. Perform the tests at page 22 of manual:
If the test does not return any error, then the door latch and motor must be tested manually as explained at page 21 of service manual.
HERE THE COMPLETE SERVICE MANUAL IN PDF FORMAT (click to open).
Regards.
Ginko
Oct 11, 2011 | GE Profile JGBP79 Gas Kitchen Range
Vehicle is sluggish and not accelerating at it should. I got stuck in traffic once as the accelerator and break pedals blocked. Requested diagnostics (I am currently abroad with no Lincoln service) and...
First error code
P1650 - Power Steering Pressure (PSP) Switch Malfunction In Key On,
Engine Off Self-Test, this DTC indicates the PSP input to the PCM is
high. In Key On, Engine Running Self-Test, this DTC indicates that the
PSP input did not change state. Steering wheel must be turned during Key
PSP switch/shorting bar damaged
SIG RTN circuit open
PSP circuit open or shorted to SIGRTN
PCM damaged."
P1703 - Brake Switch Out Of Self Test RangeP1780 - Transmission Control Switch Out of Self-Test Range
Jun 15, 2011 | 2004 Lincoln Aviator
Where is the diagnostic plug exactly located in my mercury sable 1992?
Under hood, driver side, front side of strut tower, mounted to fenderwell
Note, this is an OBD1 connector. You will need an OBD1 scanner to read codes.
Alternate methods to extract trouble codes:
USING THE ANALOG VOLTMETER See Figures 3 and 4
Service codes will be represented by pulsing or sweeping movements of the voltmeter's needle across the dial face of the voltmeter. Therefore, a single digit number of 3 will be reported by 3 needle sweeps. However, a service code is represented by a 2-digit or 3-digit number, such as 23. As a result, the Self-Test service code of 23 will appear on the voltmeter as 2 needle sweeps, then after a 2 second pause, the needle will sweep 3 times.
Connect the analog voltmeter as follows:
  1. Turn the ignition OFF .
Fig. Fig. 3: Voltmeter hook-up
Fig. Fig. 4: Analog voltmeter output code format
  1. Set the voltmeter on a DC voltage range to read from 0-20 volts.
  2. On all EEC-IV vehicles, connect the voltmeter from the battery positive post to the Self-Test Output (STO) pin of the large Self-Test connector. On all other vehicles, connect the positive voltmeter lead to the EEC STO line and the negative lead to engine ground, then jumper the EEC Self-Test Input (STI) to ground.
USING THE MALFUNCTION INDICATOR LIGHT (MIL) During the Self-Test,a service code is reported by the malfunction indicator light. It will represent itself as a flash on the CHECK ENGINE or SERVICE ENGINE SOON light on the dash panel. A single digit number of 3 will be reported by 3 flashes. However, a service code is represented by a 2-digit or 3-digit number, such as 23. As a result, the Self-Test service code of 23 will appear on the MIL light as 2 flashes, then, after a 2 second pause, the light will flash 3 times.
Mar 10, 2011 | 1992 Mercury Sable
Steps
Jul 22, 2010 | Lexmark C530dn Laser Printer
IBM / Lexmark 1464 - ''143 Service Motor Error''
throwaway, i would say replace it but would cost more
Jul 21, 2009 | Office Equipment & Supplies
Printer is hungup on self test
Mar 17, 2009 | Office Equipment & Supplies
I have 3 codes that showed up in the computer of my 1995 Ford Windstar
Here is the first half of the codes look till you find the one you have
111 System PASS.
112 ACT sensor circuit grounded.
113 ACT sensor circuit open.
114 ACT sensor is out of Self-Test.
116 ECT sensor is out of Self-Test.
117 ECT sensor circuit grounded.
118 ECT sensor circuit open.
121 TP sensor is out of Self-Test.
122 TP sensor input is less than Self-Test minimum.
123 TP sensor input is greater than Self-Test maximum.
124 TP sensor input voltage is greater than expected.
125 TP sensor input voltage is less than expected.
128 MAP vacuum hose damaged or disconnected.
129 Insufficient MAF input.
136 HEGO sensor circuit indicates system lean (Right HEGO).
137 HEGO sensor circuit indicates system rich (Right HEGO).
139 No HEGO switching (Front Side).
141 Fuel system indicates lean.
144 No HEGO switching (Left Side).
157 MAF sensor circuit open.
158 MAF sensor shorted to power.
159 MAF sensor is out of Self-Test.
167 Insufficient TP input change.
171 Lack of HEGO switching (Rear Side).
172 HEGO sensor circuit indicates lean. (Rear Side).
173 HEGO sensor circuit indicates rich. (Rear Side).
174 Check for diluted engine oil.
175 Lack of HEGO switching (Front Side).
176 HEGO sensor circuit indicates lean. (Front Side).
177 HEGO sensor circuit indicates rich. (Front Side).
178 Check for diluted engine oil.
179 Fuel system at part throttle lean adaptive limit, system rich (Rear Side).
181 Fuel system at part throttle rich adaptive limit, system lean (Rear Side).
182 Fuel system at idle lean adaptive limit, system rich (Rear Side).
183 Fuel system at idle rich adaptive limit, system lean (Rear Side).
184 MAF sensor input voltage is greater than expected, in range.
185 MAF sensor input voltage is less than expected, in range.
186 Closed loop injector pulse width longer than expected.
187 Closed loop injector pulse width shorter than expected.
188 Fuel system at part throttle lean adaptive limit, system rich (Front Side).
189 Fuel system at part throttle rich adaptive limit, system lean (Front Side).
193 Flexible Fuel sensor circuit failure.
211 PIP circuit failure.
212 Loss of tachometer/IDM input.
213 EEC SPOUT circuit open.
214 CID circuit failure.
215 PCM detected coil 1 primary circuit failure.
216 PCM detected coil 2 primary circuit failure.
217 PCM detected coil 3 primary circuit failure.
218 Loss of ignition diagnostic monitor signal-left side.
219 Spark timing defaulted to 10 degrees, spark output circuit open.
221 Spark timing error.
222 Loss of ignition diagnostic monitor signal-right side.
223 Loss of dual plug inhibit control.
224 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
225 Knock not sensed during dynamic response test KOER.
226 Ignition diagnostic monitor signal not received.
232 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
238 PCM detected coil 4 primary circuit failure.
241 Ignition control module to PCM ignition diagnostic monitor pulse width transmission error.
244 Cylinder Identification circuit fault present when cylinder balance test requested.
311 Secondary air injection system inoperative during KOER self-test (bank #1).
312 Secondary air injection system misdirected during KOER self-test.
313 Secondary air injection system not bypassed during KOER self-test.
314 Secondary air injection system inoperative during KOER self-test (bank #2)
326 PFE sensor circuit voltage lower than expected.
327 PFE sensor circuit voltage below Self-Test minimum.
328 Exhaust gas recirculation valve position sensor closed voltage lower than expected.
332 Insufficient EGR flow.
334 Exhaust gas recirculation valve position sensor closed voltage higher than expected.
335 PFE sensor circuit voltage out of Self-Test range.
336 PFE sensor circuit voltage higher than expected.
337 PFE sensor circuit voltage above Self-Test maximum.
338 Engine coolant temperature lower than expected (thermostat test).
339 Engine coolant temperature higher than expected (thermostat test).
341 Octane adjust service pin open.
381 Frequent A/C clutch cycling.
411 Cannot control RPM during KOER low RPM check.
412 Cannot control RPM during KOER high RPM check.
415 Idle Air Control system at maximum adaptive lower limit.
416 Idle Air Control system at upper adaptive learning limit.
452 Insufficient input from VSS.
453 Servo leaking down.
454 Servo leaking.
455 Insufficient RPM increase.
456 Insufficient RPM decrease.
457 Speed control command switch(s) circuit not functioning.
458 Speed control command switch(s) stuck/circuit grounded.
459 Speed control ground circuit open.
Jan 15, 2009 | 2001 Ford Windstar
Service require E008
E008. Is a Main Motor Problem.
Main Motor, Engine, power unit
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Make sure inside on unit, has no toner spilled in it.
Feb 14, 2008 | Epson AcuLaser C1900 Printer
Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Jan 29, 2007 | HP LaserJet 4350 Printer
Lexmark C532n Color Laser Printer Logo
4,117 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
