Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Changing the belt
I have a Eureka "The Boss" SmartVac. I took the bottom cover off to replace the belt. There is no way to get a belt around the drive shaft; there is no gap between the end of the shaft and the side of the vacuum in which to slide the belt. Does the shaft telescope somehow to allow you to get the belt around it? The last time the belt broke, I had a friend take the vacuum apart in many pieces to get the belt around the shaft. I cannot believe you have to go through 45 minutes of disassembly to get a belt on. The instructions say to simply take 3 screws off the bottom plate, take the bottom plate off, and then put the belt on. I'm stumped.
  • 1 more comment
  • Anonymous May 08, 2008
    I have the same problem and no, removing the brush makes no difference, as the belt is wrapped around the motor drive. I will relent and call  the  Customer Service number tomorrow if I can't find any other assistance.
  • sorensen834 Feb 16, 2009
    Following the exact instructions, I have everything reassembled, but the roller won't re-engage. It just clicks back to the bare floor setting.
  • Anonymous Mar 10, 2009
    I couldn't figure out how to change the belt on my Eureka Boss, so I had my husband look at it since he has more time. So he got his buddy involved and after a couple hours of ramming and banging - well ... some husbands are good at some things.
Just in case you're still having this problem.... you don't need to fit the belt around the motor shaft. Only wrap it around the brush roller and the piece near the back that you are able to put the belt around, and snap the brush back into place. It didn't look like it would work (it looked like my cat could have done the same thing and gotten the same result) but it works gloriously now!
Hope this helps.
Posted on Jun 07, 2008
  • 3 Answers
Have you pulled the roller out? Once you take the bottom plate off, the roller should slide out of its slot. Then you should easily be able to access the motor shaft.
Posted on May 05, 2008
How to replace the belt on a 4703 Electrolux vacuum
Instructions for changing the belt are found on page 20 of the manual (4700 series). A downloadable, printable manual is found at the below site.
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Mar 09, 2011 | Electrolux Eureka Boss SmartVac Vacuum...
How to replace belt on a eureka boss vacuum
if you look on the base plate you should see a diagram of how to do it,but if yours don't have a diagram then remove the screws from the base plate it should be three or four they have arrows next to them. take the base plate off and remove the brush roller and the old belt off being sure to put on bear floor then put the belt on the drive shaft put the brushroller in left side first
Jun 28, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Jul 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Aug 11, 2008 | Eureka Vacuums
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
386 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
