Question about Dell 1110 Laser Printer
I turned on my Dell 1110 printer and it keeps making the same noise over and over. The top "rollers" keep moving and I am not printing anything. I had to turn off the printer because it was getting so hot.
    Problem Solver:
  • 10 Answers
It does have a high pitched noise when it first starts up that is annoying, but after a few minutes it stops. If the roller is keep moving and non-stop, maybe you should contact dell.
Posted on Aug 20, 2010
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Printer roller will not engage paper
Make sure you have plenty of paper in the tray, this may help the printer pick it up. if you don't have lots of paper add an A4 sized magazine, book or old printed paper in there, to full the tray.
Is there a way to manually insert the paper from the back, some printers have this feature.
Feb 10, 2014 | Office Equipment & Supplies
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
Ink is not printing dark enough
Make sure there is toner.
Replace the transfer roller
Replace the toner
Replace the fuser.
The holy trinity of laser printing problems.
Dec 18, 2012 | Dell 1110 Laser Printer
Printer won't take paper
Regarding the paper not engaging with the Dell 1110 Mono Laser Printer, I previously read somewhere that taking iso-propanol (everyday rubbing alcohol, $1.00 for 24 ounces) and cleaning the centrally-located black roller (located just above the leading-edge of the paper) with a cotton-ball and the alcohol could solve the problem and it did -- My Printer Is WORKING. I was shocked! Actually, I couldn't find our bottle of alcohol, so I substituted with a chemically similar product. I used hand-sanitizer which is about 70% v/v ethyl alcohol -- a similar enough solvent. My Dell 1110 is working like it's brand new. Also, I wasn't able to rub the alcohol on the back side of the roller -- just a logistics problem that I couldn't solve without removing the entire roller. If anyone knows how to remove the rubber roller in 5 or less easy steps, I would love to know.
Mar 07, 2012 | Dell 1110 Laser Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Have a dell 1110 printer that will not pick up paper. Roller has been cleaned of dust with alcohol pad
You may want to try looking at the rollers through the back of the printer when it tries picking up paper. Look and try to see if the roller assembly is even turning the rollers. If that works fine and you can see the rollers trying to push the paper into the paper path, there may be something blocking the paper from going through. Pull the paper tray out and inspect it for any damaged or missing parts. Then look on the underside of the printer where the paper path begins. Chances are there is just some jammed paper keeping any more pages from going through. If the rollers have been cleaned they could just be worn out and need replacing. Contact Dell tech support if you can't fix it yourself or need any parts.
May 20, 2011 | Dell 1110 Laser Printer
Can't install cartridge - carriage won't move to center?
924 dell pinter keeps paper jamming makes noise like it is printing and grating noise
Jan 31, 2010 | Dell 924 All-in-One InkJet Printer
Won't print from tray 1...
Hi banelson: Tray #1 pickup problems
Possible Solutions:
1. Dirty,worn,or deformed multi-purpose tray pickup roller.
A. if dirty, clean the roller.
B. if worn or deformed,replace the roller
2. Defective separation pad.
A. if dirty,clean pad. if worn or deformed,replace pad
3. Damaged drive gears.
A. Check the drive gears in the pickup/feed area. if damaged,replace the gear.
4. Defective multi-purpose tray pickup solenoid.
Dec 19, 2008 | HP LaserJet 3600n Printer
Dell 1110 Laser Printer Logo
219 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
