Question about KLH KD1220 DVD Player
Can I run a Playstation 2 through my DVD player to my T.V.? Iss there an input?
  • KLH Master
  • 11,800 Answers
No, there isn't.
Posted on Aug 20, 2010
How to fix a input/turbine speed sensor on a 2009 Chevy Traverse
DTC P0717: Input Speed Sensor Circuit Low Voltage
If you don't know anything about automotive electronic's , sensor electrical circuit's ,your best bet would be to take your vehicle to a qualified repair shop.
Finding a wiring diagram ,reading how this sensor work's an testing the electrical circuit using a DVOM - digital volt ohm meter , going by a factory service repair manual .
Diagnostic Fault Information
Circuit/System Description
The input speed sensor (ISS) is a hall-effect type sensor. The sensor faces the 1-2-3-4 and 3-5-R clutch housing machined teeth surface. The sensor receives 8.3-9.3 volts on the input/output speed sensor (ISS/OSS) supply voltage circuit from the transmission control module (TCM). As the 1-2-3-4 and 3-5-R clutch housing rotates, the sensor produces a signal frequency based on the machined surface of the 1-2-3-4 and 3-5-R clutch housing. This signal is transmitted through the ISS signal circuit to the control solenoid (w/body and TCM) valve assembly. The control solenoid (w/body and TCM) valve assembly uses the ISS signal to determine line pressure, transmission shift patterns, torque converter clutch (TCC) slip speed and gear ratio.
Circuit/System Verification
Engine idling, observe the scan tool Transmission ISS parameter while varying the engine speed. The Transmission ISS parameter should change with the engine speed and not drop out.
Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Your best bet ,take it to a qualified repair shop.
Dec 09, 2017 | 2009 Chevrolet Traverse
Can the input speed sensor on a 2009 GMC Acadia be changed without having to remove the transmission
Did you do the diagnostic's that go to that code ?
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Input Speed Sensor Supply Voltage
P0717
P0717
P0716
Input Speed Sensor Signal
P0716, P0717
P0716, P0717
P0716, P0717
P0716
Ignition OFF, remove the control valve body cover. Refer to Control Valve Body Cover Replacement.
Connect the TCM harness connector.
Disconnect the input speed sensor (ISS) from the control solenoid (w/body and TCM) valve assembly.
Connect the J 38522 between the supply voltage terminal B and ISS signal terminal A at the control solenoid (w/body and TCM) valve assembly. Refer to Control Solenoid Valve and Transmission Control Module Assembly Input Shaft Speed/Output Shaft Speed Input Test for further instructions.
Set the J 38522 signal to 8 volts, the frequency to 120 and the percent duty cycle to 50.
Ignition ON, observe the scan tool Transmission ISS parameter. The scan tool Transmission ISS parameter should be between 100-400 RPM.
? If not within the specified range, replace the control solenoid (w/body and TCM) valve assembly.
If all circuits test normal, test or replace the input speed sensor.
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement.
Remove the oil cooler inlet hose (1) from the retainer on the control valve body cover.
Remove the oil cooler outlet hose retainer nut (5) from the control valve body cover.
Remove the oil cooler outlet hose (4) from the retainer on the control valve body cover.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the left engine splash shield. Refer to Engine Splash Shield Replacement.
Drain the transmission. Refer to Transmission Fluid Replacement.
you don't need to pull thr trans .
Feb 19, 2017 | GMC Cars & Trucks
Is Magnavox DVD player and playstation 2 compatible to insignia tv
sounds like the learning curve hasn't kicked in yet put the tv and the correct input and I'll bet it works
Mar 02, 2015 | Insignia Televison & Video
Today my tv's video iss flickering some times it goes to the static but mostly its lines going up the tv screen changing the colors to black and white sepia or looks like and old VHS vido thats way old...
It could be a loose connection on one of the input lines. try a dvd player plugged right into the tv. If the problem still is there then it is not the signal its the TV itself. if the dvd player looks ok then the bad signal could be from the converter box or something else on the line infront of the input signal
Jun 21, 2011 | Televison & Video
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Hi i want to know how to connect my gamecube to my portable dvdplayer
I'm going to assume you are trying to be able to play both gamecube and the dvd player on one tv. Not at once, but I'm guessing you think you can't hook both to the TV. If you no matter what big tv it is, you can connect it to your tv.
If your trying to connect the gamecube to the dvd player then you need to have inputs and outputs on the dvd player itself. hook the video and audio of the gamecube to the input of the dvd player and the ouput of the dvd player to the input on the tv
Aug 09, 2009 | Pyramat PM450WR for PlayStation 2,...
Video input help
Hi....
Get a new A/ V cable for the PS2
Mar 22, 2009 | Sony PlayStation 2 (PS2) Console
Playstation sound thru bose system
http://www.us.playstation.com/Support/PS3/GettingStarted/default.html
you have a few options. Does the bose accept optical input.
the easiest is for you to use component out and take the 3 video outputs to tv and the 2 phono to the sound.
Apr 01, 2008 | Toshiba SD-1200 DVD Player
About installing my cd/dvd player to my console
This is a bit confusing. You cannot hook a CD/DVD player up to the PS2 console. If your trying to figure how to hook a PS2 console and a CD /DVD player up to a AV system. you need to hook the PS2 Yellow, White and Red cables to any input. Not just a DVD or CD input. Yellow is Video you need that. Hook the red and white to the same selected input.
Dec 01, 2007 | Sony PlayStation 2 (PS2) Console
Changing input jacks
has your remote control got a AV button on if so then press this till AV 3 if your video has 2 scarts at back and av jacks in front if your remote has not got AV button press the ch- key till you see AV3 on desplay. If you still have the user manual refer to this. hope all goes well
Aug 20, 2007 | Emerson EWD2204 DVD Player/VCR
KLH KD1220 DVD Player Logo
43 people viewed this question
Top KLH Televison & Video Experts
Steven Wander
Steven Wander
josepovedaca
Level 1 Expert
ray gallant
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
