Question about KitchenAid 30 in. KGCS105GSS Gas Cooktop
When second igniter is turned on, circuit breaker blows
  • KitchenAid Master
  • 909 Answers
Normally if trip switch activates, it means there is a problem on the ignitor board. Easiest way is to replace it. Trying to repair it is like playing dice. A good repairer is pricey and a poor repairer is costly.(At least with a new board, there is a gaurentee.) Unfortunately it should be replaced by a responsible technician as the gaurentee is not valid if done by a non technician.
Posted on Aug 20, 2010
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
Will not ignite. I have reset circuit breakers. what else to do?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
May 13, 2010 | Cooktops
The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Dec 11, 2009 | KitchenAid 30 in. Architect KECC507KSS...
Burner does not work, blows circuit breaker
replace the control and the burner.
Find at appliance parts store near you or at www.repairclinic.com
Valuable information? leave positive comment
Not valuable? My name is Joe Blow and I never said it
a
Oct 12, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
GAs burner igniter
This is definitely an electrical problem. Check the circuit breaker on the wall plate (where the cooktop is plugged in) as well as at the fuse box. If that is not the problem, you may need an electrician.
Feb 19, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
GE JCP 930 Cooktop Wiring
These fuses are under counter? It should be wired to breaker box. Check specs in manual but i suspect a 30 or 40 amp breaker.
Nov 17, 2007 | Maytag MEC5430 Electric Cooktop
KitchenAid 30 in. KGCS105GSS Gas Cooktop Logo
112 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
freddyfox
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
