Question about Vacuums
Nilfisk Sprint PLus :Opened vac to change bag and now can't close? Or do you have manual?
I got this vac from a cousin who has since moved OS, so I don't have the manual...I"ve opened up the vac to put in a new bag and now I can't close it??
  • Anonymous Jul 24, 2008
    need a solution to the problem above
3 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: Nilfisk Sprint Plus - machine
Hi, sounds as though you have a clogged hose somewhere which in turn makes the motor get hot.
Try running a wire up through there and see if there may be a piece of something stuck crosswise, that happened to my vacuum..
I would recommend running a broom handle through the hoses if you're going to search for clogs in the line. A wire hanger could rip the hose.
Posted on Mar 25, 2011
EwingElect
  • 276 Answers
SOURCE: How do you change the dust bag on the Nilfisk King...
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
Posted on May 25, 2010
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Power keeps turning off on Nilfisk vacuum
What kind of vacuum is this? If it is a pushbutton switch you may need to replace the switch.
Oct 24, 2013 | Nilfisk Family Vac Bagged Canister Vacuum
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
How do you change the dust bag on the Nilfisk King 505?
May 20, 2010 | Vacuums
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuums Logo
318 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
