Dear Sir/Mada, i have laptop Acer Aspire 2000. that laptop lcd is dark. i did not display screen.
    Sergeant:
  • 238 Answers
  1. Check ur powercord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Posted on Aug 20, 2010
Black screen on Acer aspire 5680
This is a case where the inverter board "located under the LCD screen" has failed or the backlight behind the LCD display is defective.
Mar 22, 2012 | Acer Aspire 5680-6516 Notebook
My screen keeps going dark. I have replaced the
Its not the inverter, it's your backlight. Hard work to change, sorry, and it might be cheaper/quicker to replace the whole lcd panel at $100 (£65)
Jul 26, 2010 | Acer Aspire 5610-2328 Notebook
Acer Aspire 3003 wlci laptop. Uses Aspire 3000 display. Problem: part of the display has a black bar on the screen. You can still see through it though. I hooked up the laptop to an external monitor. No...
i think you have the ability to check your laptop and the only i can suggest to you is you have to check the backlight section of your laptop cause there might me cold solder parts that cause the dark side of your screen.
Oct 05, 2009 | Acer Aspire 3000 Notebook
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
Acer dark screen problem
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
I cannot say how many I have replaced in Acer systems
I know for a FACT this is the problem. They are cheap inverters.
When you replace this one i would expect it to last longer :)
Jul 10, 2009 | UltraLast ULAC3660L For Acer Aspire...
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
Jun 23, 2008 | Acer Aspire 3100-1405 Notebook
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Acer aspire 5315
Since the Acer Aspire 5315 works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Acer Aspire 5315.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
David Payne
David Payne
