Question about Olympus Cameras
Olympus stylus tough 8000 camera will not turn on. the lense opens then closes back up automatically a few seconds after and nothing else happens. It started after I was uploading pictures on my computer. It does turn on though when I plug in the camera into the computer.
  • 4 Answers
SOURCE: Olympus stylus 700 all weather
Have you checked the battery. If you have charged it then it may be a bad battery. also if you are in a cold climate try putting the battery in your pocket for a little while. This is what the manual has to say.
Hope I have been of help.
Posted on Apr 17, 2008
  • 699 Answers
SOURCE: microSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Posted on Mar 07, 2010
  • 72 Answers
SOURCE: how do i install my olympus 6020 on my computer?
Go here and download the drivers:
http://www.olympuscanada.com/cpg_section/cpg_support_downloads.asp?id=1496
After you can download the pictures and videos to your computer.
Posted on Jul 27, 2010
  • 3 Answers
SOURCE: My Olympus Tough 8000 charges up to a blue light
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Posted on Sep 14, 2010
SOURCE: my olympus stylus tough 6000 beeps then turns off
I had the same problem and all I did was play around with the shutter .. I took a soft tooth pic and played around with the shutter, it seemed that salt from the ocean had crusted around the edges .. once removed the camera worked fine .. hope this helps
ps I had even bought another battery thinking it was the problem since when I connected the camera to the computer it worked, but I hadn't realized that when connected to the computer it's not able to take pictures, hence the shutter was not used ..
Posted on Mar 16, 2011
Turns off when cover is closed
First don't spent too much mont for repairs, because cameras are becoming cheaper and cheaper and in the mean while better and better.
You could try to open and close the cover several times and hope it starts working as it should. It has a switch connected to it, so the camera can see if the cover is open or closed. Now it is giving the wrong information. If the camera comes on, when the cover is open, that indicates the battery is still good, unless the it stops working within a short period of time.
Jan 27, 2014 | Olympus Stylus Tough 3000 Camera Digital...
Olympus Tough 8000 wont charge
Rechargeable batteries will fail if stored for long periods in a partly charged or in a zero charge state.
You need to replace this battery with a new one.
Sep 27, 2012 | Olympus Stylus Tough 8000 µ Tough 8000...
Card door error
Is memory card fully seated? Also check to see if there is any lint inside the catch.
Jan 24, 2012 | Olympus Stylus Tough 8000 12 MP Digital...
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
My olympus tough 3000 will not turn on, when i turn on orange light at the top just stays on but nothing comes up on the screen
.' i have a problem with my camera olympus u tough 3000, when i turn it on..it is okay but after 4 or 5 seconds it will automatically shut off.. help me please... if what should i do.. what is the best solution to fix this..
Aug 05, 2010 | Olympus Mju Tough 8000 Compact Digital...
Have 2 tough cameras new, no reciepts both daughters did not keep reciepts., both took camera in ocean, one does not turn on at all and other turns on for a few seconds,lens does not open, obvioously...
You can try wash again in pur ewater with out batteries and leave to dry in hot press or very warm area of house for a few days 5 days min. then put back battery and say a nice little prayer before you press the pwer button and who knows The Man above may answer your request.
Nov 30, 2009 | Olympus Mju Tough 8000 Compact Digital...
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Cameras Logo
286 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
