Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Displays HL and has been on for hours but not heating. Help!
    Problem Solver:
  • 6 Answers
HL usually indicates high limit which will shut down the unit. if power is turned off for a min or two it may result the fault. on some units there may be a reset button in the control unit. if it doesent reset it is most likely the hl thermal (temperature) sensor hope this helps
Posted on Aug 20, 2010
I need instruction for the timer
You posted under Woods 59403 timer
If this is not your timer, add a comment.
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
If you have different Woods timer, look at images at link below to identify timer.
Add a comment if you need help.
http://waterheatertimer.org/Woods-timers-and-manuals.html
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Plug lights into timer.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I would like to have the instructions for operation of the Timer.
Add a comment at any time
59403 timer manual:
Set clock:
Program timer:
This is Event1 ON
This is Event1 ON
This is Event2 ON
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
I have a samsung dlp 50" model # hln5065xxa. After an hour or so the screen starts flashing in different areas in which makes the people on tv to look negative
do you have a picture so i can see better?
its to hard o tell you what is wrong because i don't have a lot of info..
maybe its the digital board.
try to go on your tv menu and let me know if it displays fine?
Jun 22, 2009 | Samsung DLP HL-P5663W 56" TV
Turning it on it displays ERROR E50.please help
You have a fuser malfunction, replace the fuser unit.
Mar 06, 2009 | Brother HL 5250DN Laser Printer
Hl 2700 cn 'no opc belt' error
You need to go into the settings and reset the counter once the new belt is in.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
Microwave heated food an hour ago but has stopped heating it now. Sensor cooking ceases and displays "F3H". Fan has stopped working also.
A make and model would have been nice, but try unplugging it from the wall outlet for 15 minutes.
Hope that helps...
Geno
Mar 26, 2008 | Microwave Ovens
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
317 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
