Toshiba satellite 2060 CDTW will not turn on, will not boot. Lights: plugged-in on, battery on, others off. When power switch is pressed, HDD light turns on and remains on with apparently no other activity, no screen image, no sound. Unit is unresponsive and turned off by pressing and holding down power switch. Sometimes, even if unit is off and unplugged, battery light remains on dimly with no other activity. Battery is pulled out to prevent drain. Unit is old but the upgrade of memory to 192mb, HDD to 40gb, and OS to win xp pro sp2 years ago brought it back to service life for common light-duty tasks. Other configurations at original. Thanks in advance for your help.
  • 1,606 Answers
Thats sounds like a ram problem. If it was cpu you should still get a beep or post code. If it can't read the first 64kb of ram in the first chip it will do this.
I would take the ram out and swap the sticks. Then try to boot. If you get it then the chip is the problem. Older ram sockets can loosen up with heat cycle, vibration etc so it could be something as simple as needing to reseat the ram stick and it will work.
The next thing to check would be the cpu. It might be the chip or the socket again.
The power light is strange but I've seen it when the cpu is out when the power transitors go on the board. It may be a fault caused from the cpu.
I still have a 486 Tosh I use. Still can't type faster (or speull bettter) now then when it was new so it still does some things just fine ;-]
Posted on Aug 20, 2010
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
My toshiba does not boot up
I do not think it is a HDD problem. When you turn it on, are you able to see something on the screen or not? If not, then it is probably problem of the motherboard.
Sattelite A50 has an 42000 rpm IDE Harddisk, buy 40GB or 80 GB.
Is it under warrenty?
Mar 19, 2009 | Toshiba Computers & Internet
Will not turn on, no lights at all
Try to remove the battery, and plug it into the wall. If it then boots, your battery has failed. This happens frequently. If it still wont boot you will need to take to someone to see if the board has died or other issues. Hope this helps
Nov 30, 2008 | Toshiba Satellite M65-S9063 PC Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
