Photo paper jammed in my mp600 canon printer. I pulled out, but error light still comes on. There is no jammed paper. I have reset it, and unplugged it, but remains.
    Genius:
  • 3,587 Answers
Not surprising..see this link for some helpful suggestions
Posted on May 03, 2008
Error 6b10
Hi there!
Here's what you can do:
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Try to check for jammed paper. click this link and under service & support type paper jam http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport 4. The MP600 may require repair
If you will still receive the message you can check this link for your model or contact the customer service http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Hope this helps!
Mar 29, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Get paper jam error, Canon MP600 All-in-One Printer
If you don't have any paper stuck in there you will need to reset your printer. you can do this by unplugging the power cord from the back of the printer and leaving it out for about 30 seconds. Plug it back in and retry
Nov 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 paper ouput slot error will not reset
canon printer is telling me that i have paper jammed in paper out slot when ther is no paper in it can it be reset? or is it not fixerable by my self.
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon Pixma MP600 printer has an error coming up of 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 29, 2010 | Canon Pixma MP600 Printer
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon MP600-where do you see Error Code? I just get "Paper output slot" paper is jammed; but it's not!
That error usually comes from the sensor under the platen roller. It's a tiny black plastic piece that the paper pushes when it passes under the platen roller. The end can bend when you pull out a jam, or a tiny paper scrap can hold it down. The same screen gives error codes when there are other malfunctions, the error now is just that sensor.
Dec 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam in canon MP600 Printer
If you cannot see the paper jam, perhaps it is inside the machine:
1) Open the rear cover and inspect the area for any bits of paper that might impede the paper path
2) On the front of the machine, pull out the cassette (paper tray) and inspect the cassette area for any paper jammed inside.
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Have the canon mp600 and like others it has the 6A00 error that won't go away. It had a paper jam and paper was pulled out- can't see if a fragment is left. May try the shaking technique- other solutions?...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message u052
That is a printhead error, sounds like you will need that new printhead.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
75 people viewed this question
k24674
jasbo
jasbo
