I unplugged the power switch,restart, hdd led,etc from the motherboard by mistake. I thought it was a single plug on the board. Can you tell me exactly where they belong? The board is from an intell pentium 4. Matsonic MS9158E .
    Genius:
  • 3,587 Answers
Perhaps...you may wish to consult this link, and provide the level of information we need, eh?
Posted on May 03, 2008
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
I got a mother board from a friend it a k9n6sgm-v but i can find where i have to connect my speaker-HDD LED my rest switch all the front panel
http://www.msi.com/service/download/manual-4593.html
If you follow the above link, you can download a pdf of the manual. On page 7 at the bottom you will find a diagram showing where to plug in speaker, power LED, HDD LED, reset switch etc.
Aug 16, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
I have a eMachine model c2685.i just need a pic for switch locations in the mother board.where the plugs from the hdd light, power sw, and thepower light plug into the mother.boardplease help
ok i might be able to help there is a motherboard swaping guide on youtube but there should be somthing like this on the motherboard ::::. the one closist to the single should be power ie ::: power: then . then its ::then reset then ::. then it should be hdd led so :then hdd led then:::. and the last is pwr light :<pwr led:<hdd led:<rst:<pwr.< blank hope this helps if it does then please give 5 thumbs up just remeber your looking for the : : : : . then follow my plan
May 15, 2010 | Computers & Internet
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
CAN YOU TELL ME HOW TO CONNECT WIRE FROM MOTHERBOARD TO FRONT PANEL?
When you say wire, I assume you meant the wires connecting those LED lights at the front of the panel. If you look closely in the motherboard, there is a small 9 pin plug at the side of the board and beside it says front pnl. One row has 5 pins and the second row with 4 pins. These pins are for the on/off button, power on led light, Hdd light and the reset button. All the plugs are marked, HDD, Reset etc. You have to try by error to find the right pin for the right plug Sirjohn
Mar 16, 2009 | Intel Desktop Board D845WN Motherboard
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
