Question about Samsung AC5900058B Remote Control
I have purchased samsung digital plano colour tv in 2003. And i have a problem with the remote it has a feature called PIP. The PIP button came out of remote and some of the buttons on remote are not working. so i want you to tell me how to get new remote and tell me stores where it is available. I have contacted the samsung customer care they told me to go to samsung service center and i have been there and they said i have a old remote so they are not manufacturing these models anymore,so if the remote of samsung tv has a problem then one has to purchase a new tv or What? please give me the solution and tell me the exact store where i get the same remote which has all the features of my tv. thank you
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
SOURCE: Making my SIR-T451 remote work with my Zenith TV.
Push the Set button and enter the following codes and enter one of theese codes: 018, 020, 193. If one doesn't work try the next one. You have to push set each time you enter a new code.
Posted on Feb 10, 2008
IrishDruid
  • 2712 Answers
SOURCE: Universal remote for Samsung Hitron
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Samsung Televison & Video
Samsung HDTV Ready TXM2798HF turns itself off
I promise you, the repair cost will breach the cost of a new television. Most electronic devices have built-in safety features to prevent A) further possible damage to the device or B) possible electrical fire and C) thermal protection for the prevention of overheating (re: a fan that isn't spinning will trigger an auto-shutdown).
Don't be scared of new technology. These so-called smart TVs have their advantages. That said, not all new televisions are "smart," as a matter of fact, they are called "dumb TVs." Many are plug and play and have very user friendly features. Simply plug the TV into the power outlet, connect your VCR, DVD, OTA HDTV antenna, Cable Box, Satellite Tuner to the TV and you're done. ALL televisions available for purchase have the ability to receive free OTA broadcast digital television. I think that is an FCC requirement.
Anyways, go to your local electronics retailer and tell them what devices you wish to connect to your new television set. It will be to your benefit to bring someone that is tech-savvy that can help you make a wise purchase.
Jan 07, 2014 | Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
How to work a sony 40 in projection tv's picture in picture feature
Locate PiP button on TV remote and press it to turn on picture in picture function and again press the same button will turn off PiP feature.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Televison & Video
Want DEFLECTION SETTING for my samsung plano 29 inch gigabass tv
I need the deflection constant from Samsung factory for adjustment TV Samsunng Plano of me.
Nov 08, 2009 | Samsung Televison & Video
I lost remote is there away to manually change tv black panels back to full screen like the aspect button without a remote? the tv is a hitachi 51f500
Unfortunately, most of these projection TV's require a remote. You CAN purchase an aftermarket remote. I would look for one that has all the features you need, PIP, screen format etc.... I have found that the Sony RM-VL600 works real well with my Mitsubishi TV... kids thrashed the remotes more than once...
This particular unit has system control PROGRAMABLE buttons on the bottom row. I've been able to program them for formatting the screen, setting audio and video... Solved my issue of needing a factory remote... KEN
Mar 31, 2009 | Hitachi 51F500 51" Rear Projection...
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Samsung AC5900058B Remote Control Logo
246 people viewed this question
Henry  Thomas
Henry Thomas
