Question about Ovens
Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    Genius:
  • 1,417 Answers
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours.
The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat.
A small indicator light will come on below the word to tell you the cooking temperature.
thank and thanks for using fixya.
Posted on Aug 20, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How do i set the clock on my mistral microwave oven
    I am also trying to find a way to set my time on my Mistral microwave oven but i still can't find a way how
    Apr 03, 2011 | Ovens
    Logik microwave user manual
    Press 'Clock' then 'Stop / Clear'.
    The display will show 0
    Set the time (it's a 12 hour clock)
    Press 'Clock' again
    Nov 02, 2010 | Ovens
    I need an instruction manual for Russell Hobbs mini-oven Model 13824-10
    Andy -
    Download for free from here in PDF format:
    http://www.russellhobbs.co.uk/pdf/product_139_13824-10.pdf
    Click the link and the instructions will open in a new window: You can view, print and/or save this file. If you need Adobe Reader to open the file, get it here:
    http://get.adobe.com/uk/reader/
    Hope this helps. Please rate this solution if you find it helpful. Thanks.
    Oct 18, 2010 | Ovens
    Wanting to set time on black and decker microwave oven model No BMO700S thank you
    For the B&D model BMO700S press the buttons in following order:
    1/ Clock button
    2/ Cancel button
    3/ Type in the time (NOT 24 hr clock time eg 5.32pm will be typed in as 0532
    4/ Clock button
    Congratulations! You have completed the task!!
    (Information from Vasilios of Rosanna, Melbourne 26/09/2013).
    Sep 04, 2010 | Ovens
    I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
    Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
    Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
    How to set time with new control board?
    You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
    This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
    Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
    Ovens Logo
    215 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
