Question about Sony AD-7191A DVD±RW Dual Layer Burner
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
  • Sony Master
  • 27,725 Answers
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
If this fails try a different burning software
Posted on Aug 20, 2010
Open tray error and thensome.
Unreadable disc errors or open tray errors are commonly fixed by pot calibration or laser assembly replacement. Pot calibration is the cheaper of the two, and if it fails and burns out the laser, well, replacing the laser would be the next step anyway.
You shouldn't calibrate the pot without an ohms reader simply because you can burn out the laser, but you CAN wing it. I'd advise doing some searching on DVD Drive pot calibration for the Xbox 360, simply because I don't know which drive you have so I can't help identify anything for you.
I will say you have to disassemble it down until you see the motherboard, take out the DVD drive, open it up, and then calibrate the pot with a very small screwdriver. The location of the pot depends on your drive. If this fails, then buy a new laser assembly and replace it in the drive.
p.s. pot calibration is fancy terminology. There are basically 2 "screws" inside the drive, 1 pot is the DVD/games, and the other is CD. You'll want to very slightly tweak the DVD/games pot until it works, testing with each tweak. You barely need to adjust this "screw" for a significant change to happen. Also, always test with a DVD and then a game. It will read a DVD before a game.
Apr 09, 2010 | Microsoft Xbox 360 Console
I have a LG CD-R?RW Drive CED-8080B/CED-8083B that has outdated software and reads burn process failed (power calibration error). I,m a beginner - don't know what this means. Need new drive? Update...
Sounds like you need to either update the firmware on the drive, or the drive is malfunctioning physically.
I'd just buy a new drive. Those things are very cheap now a days. Don't waste your time trying to fix it unless you can find an easy fix.
Feb 05, 2010 | Computers & Internet
My atapi dvd a dh20a3p dvd writer keeps comming up with same error when i try to burn using nero the error is power calibration error how do i fix this and do i need to update the firmware as driver is...
I found the upgraded firmware for your drive here: http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153
Disks have a test area on them where the drive can test write to calibrate laser power for the disk. This power calibration error means that this test write has failed for some reason. The most likely causes are bad media, a dead or dying drive, or a bad power supply. Try different media. If it is getting that error on the same drive with different media, check out your power supply fast!!! If it is an oem computer, they tend to use a cheap power supply that is just good enough to run the computer. If your power supply fails, it can other things in the computer. Download something that can monitor voltage. As these are not always accurate but its a starting point. Perhaps try monitoring voltage while you try a burn. You can also try reducing power usage (unhook usb/firewire devices, unplug power to extra hard drives etc. If it is testing with bad voltages and/or if reducing the amount of power fixes it, stop using the computer and replace the power supply fast before you have more damage to your computer.
Hope this helps
Sep 24, 2009 | Computers & Internet
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
SONY DVD RW AW-G170A BURNING PROBLEMS
It worked with Win ME but not with Win XP now
Aug 23, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Power calibration fix for a Matsushita UJ-831B. My drive will copy a CD or DVD but it fails to burn either, and says power calibration error
Try to swop the disc that you have for another one-it will very likely burn to the the replacement.Some discs are troublesome.
Jul 23, 2008 | Panasonic Computers & Internet
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Sony AD-7191A DVD±RW Dual Layer Burner Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
