Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
Hello Sir, When SMPS for motherboard burnt, all LEDs of Keyboard and CPU were constantly glown but system switched off. PC not getting on even after replacement of SMPS. When checked input power supply, neutral to earth voltage found 30V. Also without switching on through CPU on/off switch,and giving input to SMPS, SMPS fan is not working and ITE make IT8705F IC (near to BIOS_WP IC) is getting very hot. Please suggest me the solution. Also I have digital multimeter so please guide me to troubleshoot the problem in detail at home. Also I live in India, so I have checked it at the shop and the cost is about Rs 1000 for repairs (if repairable). The processor is AMD athlon. So suggest me the economical alternative instead of repairs, if available. Thanks
    Top Expert:
  • Gigabyte Master
  • 12,962 Answers
Get a good used mo bo on ebay to replace the one you have.
Make sure you get the exact replacement and it will go right in and you will not have any hassles with compatibility/driver issues.
Lot cheaper!!!!!!!!!!!!!!!!
Posted on Mar 21, 2017
  • 12 Answers
SOURCE: not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Posted on Feb 05, 2008
  • 101 Answers
SOURCE: No Beep No Display
Hi you need to check the Processor and the power distribution logic on your motherboard . Check the processor on another mobo if possible to ensure its working . Next check the Voltage regulators around the power connector and the ports if you have a multimeter , look for 3.3 volts ,5 volts and 12 volts . Check if any of the electrolytic capacitors have short circuit . If you find any of the capacitors bulging desolder them and power-up the mobo .
Posted on Jul 11, 2008
  • 63 Answers
SOURCE: Motherboard
i believe your motherboard is already bad. have it replaced.
Posted on Oct 06, 2008
  • 24 Answers
SOURCE: New motherboard - system shuts down at windows login screen.
Fiend your solution direct from Gigabyte. Here is your solution.....
Posted on Mar 02, 2009
  • 120 Answers
SOURCE: System wouldn't power up and when i replaced the
You've probably reset the bios, so we won't belabor the point. Sounds like the motherboard is toast. You replaced the power supply, and that was probably the culprit, but it took out the MB as well.
A 478 board is older, but you should be able to eBay one with similar specs.
Posted on Jan 08, 2010
Testimonial: "Thanks. Believe you're on the money.Oh well-will look for replacement board. DA"
I need info about what the cpu phase leds on aN msi 990fxagd65 mean
They indicate the number of different power phases that the CPU is currently using. In order to save power the motherboard is able to reduce the voltage to (and performance of) the CPU. In 2 phase mode (2 LEDs) it basically switches between high performance, and low performance. 4 LEDs means that there are two additional intervals in between the high and low power settings. 6 LEDs indicate six total phases, etc.
I believe that there is a greater possibility of system instability as you increase the number of phases that the motherboard switches through.
Oct 22, 2012 | MSI 990fxa-gd65 Motherboard Am3 Amd990fx...
I have an Intel D845EPI/D845GVSR Motherboard with 512MB PC266 Hynix DDR1 RAM. When i switch on my PC, the system starts but, fails to display even the first screen that it is supposed to display...
Couple of items to try. First disconnect everything except the power and the CPU. Does it give you a beep code?
If not your either have a bad power supply, motherboard, or cpu. (Only if everything else is disconnected.)
Second, If you did get the beep code then put the memory in and see if the system starts to boot. (Try without the screen connected first. If it acts like is going to start turn it off, plug in the mouse, keyboard, and monitor and try again.) ** I have seen where an add on video card would keep the computer from starting so try with the on board video first.**
Third, start adding one extra piece at a time starting with the hard drive.
Let me know if this helps or not.
Apr 22, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
P4B-M standby LED lighted and CPU fan jerked a little and stopped when power is plugged into the power supply unit. The motherboard does not seem to power up/ CPU fan remain still even the power switch on...
This is an issue with the power supply (SMPS) in your computer... Replace the SMPS will fix the issue...
It is not adviced to service the SMPS, because servicing the SMPS will not give proper power supply to the board, which may result in damage of Motherboard...
Dec 15, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Power supply works but pc doesn't power up no lights and fans dont work
Have you checked the power supply in different system? If yes then first replace CMOS battery and switch the CMOS battery jumper. And while doing this please unplug the hard disk or optical drive data cables and power. If it does not work then check the power switch is working or not or it is perfectly connected with the front panel PINS on the motherboard. If it is not connected perfectly computer will not start after pressing power button.
Second Level Test : Remove the CPU Fan - replace the CPU perfectly - again place the Fan.
Third Level (motherboard test): Just take the motherboard removing CPU,RAM, SMPS - use another same type CPU, RAM and SMPS - if it does not work so it is motherboard problem. If it works may be CPU problem.
Jun 12, 2010 | Gigabyte GA-8LD533 Motherboard
Not switching on
wrong or bad cpu
Aug 30, 2008 | Computers & Internet
Please help
if your cpu can't heat so your mobo vrm circuit fail ic no: adp3168 near by cpu
Mar 29, 2008 | Intel D845GVSR Motherboard
Pc won't power up
Dear Buddy117,
What i have understand that u r Motherboard getting the power supply but i want to know that is u r SMPS power supply fan rotating or not if no then u have to change the SMPS if it is ratating then u have check the power switch in u CPU cabinate is that power switch wire properly connected to the motherboard if it is connected then check wether it is connected in right place or not i hope this information will going to help you.
Feb 14, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
Nov 29, 2007 | Intel Motherboard
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
69 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
