Question about Dryers
What is the BTU rating on the Duet electronic gas dryer?
    President:
  • Dryers Master
  • 2,651 Answers
20,000 btu raitn on the duet burner assy
Posted on May 03, 2008
Switch the 3 prong cord to a 4 prong on my whirlpool duet sport, 9 cycle
Hi mybabycamero
Go to the following webpage and you can see how to convert your 3 wire to a 4 wire dryer.
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 17, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I need to put my 4 prong cord onto my whirlpool duet dryer
Hi mybabycamero
Go to the following webpage and you will see how to change your 3 wire into a 4 wire dryer.
Bud
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
I have a Maytag performa poropane dryer. It states the input rating at18000 btu per hour. I have a 5/8 inch OD flexible gas line at 48inches long it is rated for 75001 to106000 btu/hr . Is this the right...
Hi and welcome to FixYa, I am Kelly.
There is nothing wrong with using a larger flexible gas line than is required. We used the 5/8 OD lines most of the time as they were much more durable than the smaller ones. The line you have is fine.
Thanks for choosing FixYa,
Kelly
Feb 09, 2011 | Maytag Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
How to check gas valve orifice to insure its correct for a LP install. VDSC5304bwh. It was ordered LP but box has been written over many times nat/LP/Nat.. Searched the web ..no help..I am a HVAC...
What is the BTU rating of the dryer. If you open the dryer door, it is listed on the dryer behind the door. Most are 20,000 or 22,000 btu. The orifice # should either br 54 or 55 if it's LP.
May 16, 2010 | Viking VDSC305-4B Dual Fuel (Electric and...
I have a whirlpool duet gas dryer. how do I open
1. Unplug the unit while servicing inside.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
1,109 people viewed this question
Top Dryers Experts
