Question about Whirlpool ACQ128 Air Conditioner
I have a whirlpool AC unit model ACQ128PW. I am unable to toggle the temp between F to Celsius. I have tried holding the /- for 2 seonds as manual suggested. Any other reprograming sequence available?
3 Suggested Answers
  • 3422 Answers
SOURCE: Whirlpool dishwasher won't work at all
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Aug 07, 2008
  • 2509 Answers
SOURCE: How do you change the
Press (precise)clean for 5 seconds, display shows temp Celsius press it again for 5 secs display shows temp Fahrenheit, press off/cancel to store
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 27, 2011
2004 Hyundai, how do I change the thermostat reading from celsius to Fahrenheit?
The climate control head defaults to Celsius anytime power is lost (e.g.dead battery). To toggle, hold in the ambient temp button and the cooler temp button at the same time. The temperature scale should switch after a few seconds of holding.
Jun 12, 2017 | Hyundai Cars & Trucks
How do I change the oven temp from celcius to farenheiton my Maytag Advanced System Model #MGR5710ADW
try unplugging range. If it does not return to F display
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
or
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit.
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4SP964
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4C5UH2
Jul 15, 2014 | Whirlpool Gold GW399LXU Gas Range
I have a red core heater how do i get from celsius to farenheit
Press the Temp UP and DOWN buttons at the same time and hold for about 3 seconds to toggle between Celsius and Fahrenheit measurements.
Oct 21, 2012 | Cars & Trucks
Subzero 850 freezer temp reads minus 20 degrees
Is it possible your unit is set to celsius rather than fahrenheit? I ran the -20c though a converter and is this is true your unit is running at -4 degrees fahrenheit and this would be a little cold but ok at this temperature. I would personally check settings before going further in to any repair. I was reaching the model you gave me and found the number you gave was incorrect. But try this; turn the whole unit off for a couple of minutes. Turn it back on, then push and hold the alarm and unit power button for 5 sec. this can only be done within the first 5 minutes of power up. This should confirm your display setting is correct, I am assuming you want fahrenheit rather then celsius. If this doesn't work for you, I will need to confirm model number so I can send you a digital version of the service manual if you need it.
Good Luck
Oct 15, 2011 | Sub-Zero 650 / O Bottom Freezer...
The stove is stuck on celsius. I pressed and held the CANCEL AND BAKE buttons for 3 seconds and nothing happens. I don't know how it got on celsius. How do I get it back on Fahrenheit?
You can get Whirlpool manuals from http://www.whirlpool.com/custserv/index.jsp
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
Mar 18, 2011 | Whirlpool GR563LXS Kitchen Range
How can i change the temperature display from celsius to fahrenheit in my 2009 dodge journey?
Click the top left button on the steering wheel (looks like a book page) toggle the display (display is right under the temp and gas gauge on the left of dash). Go to Units and change between U.S. And metric to toggle from farentheight to Celsius an visa versa. It also changes between miles and kilometers, gallons / kilograms, etc.
I hope that helps - it took me a minute to figure this out.
Mar 04, 2011 | 2006 GMC Sierra
I have a instant ear thermometer model number 524972 and it is stuck in celsius, how do i get it back to Fehrenheit
When the unit is off, press and hold the blue start button at the top of the unit. Then while still holding the start button, press and hold the ON/Memory button (you should now have both buttons pressed). The display will power on and you will see the setting toggle from celcius to fahrenheit. Once the setting has changed you can release both buttons. Repeat the entire process in order to toggle the setting back to celcius.
Jan 18, 2011 | Becton Dickinson BD Instant Ear...
Range got switched to "Celsius", how can we get it back to "Farenhight"
If the model number is correct, to change from Celsius to Fahrenheit (and vice-versa) follow these steps:
1. Press and hold the AUTO/CLEAN button for 5 seconds and TEMPERATURE UNIT FAHRENHEIT should appear.
2. Press OFF/CANCEL to exit mode.
Repeat the same steps if you ever wish to change back to Celsius.
These instructions are printed on page 11 of your owner's manual. If you cannot find your copy, go to managemylife.com and type in your model number under the "Manuals" link. Your installation and owner's manuals are available in .pdf (Adobe) format that you can download or print for FREE.
If this is not your model number, please post back and let me know. I hope this helps you.
Mar 05, 2010 | Whirlpool GR448LXPQ Electric Kitchen Range
We have a whirlpool range GR448LXPQ and some how the range got switched to "Celsius", how can we get it back to "Farenhight"
If the model number you have this question listed under is correct, to change from Celsius to Fahrenheit (and vice-versa) follow these steps:
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Whirlpool ACQ128 Air Conditioner Logo
115 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
