Question about Koiiler Car Audio & Video
What amp fuse does koiiler xm 8787 use - Koiiler Car Audio & Video
Cerfer39
  • 709 Answers
SOURCE: Size
http://www.termpro.com/articles/buildbox.html
Try this link for building a box, it is cool.
Posted on Nov 25, 2007
SOURCE: I have a Koiiler xm-6688,
No Thanks
Posted on Nov 20, 2008
  • 53 Answers
SOURCE: I have a Koiiler xm-8787 and it has power going to
sounds like it could be your earth i hope so please check its nice and tight
Posted on Oct 24, 2009
SOURCE: Hi... When I adjust my radios balance to full
mine is doing the same thing one hits harder than the other any known causes send an e-mail dirtydog98006@aol.com
Posted on Jan 22, 2011
  • 111 Answers
SOURCE: I have a Koiiler XM-6666
You need to match what is on the amp. If the amp has a single fuse, or multiple fuses rated at a total to 80, then you need to use an 80 amp fuse at the battery.
Posted on Apr 23, 2011
I have a Koiiler XM-6666 2 channel amp. I was wondering what size fuse i use from the battery source to the amp its self.
Apr 22, 2011 | Koiiler XM-6666C Car Audio Amplifier
I have a koiiler xm-8787 1000w amp. the problem is when i hook everything up correctly, the dual 10 inch sub make a repeating papapapapapapa none stop and doesn't produce bass. could it be the amp is...
I HAVE THE SAME AMP IN MY CAR RIGHT NOW ! THATS NOT NORMAL THATS FORSURE THERE SHOULD BE A X-OVER SWITCH ON THE SIDE OF IT SWITCH IT T0 LPF (LOW PASS) THERE SHOULD BE A DIEAL LABELED THE SAME THING ADJUST IT TI 75% TURN YOUR BASS BOOST TO 25% AND THE LEVEL SWITCH TO 25% THE HPF DIAL WONT WORK UNLESS YOU SWITCH YOUR X-OVER TO HPF BUT YOU DONT WANT THAT, THAT HAS TO DO WITH THE VOICE3 COILS IN THE SPEAKER THATS PROBABLY YOUR PROBLEM! YOU WANT TO RUN YOUR SPEAKERS WIRES PARRALLEL WITH A DOUL VOICE COIL SPEAKER IT SHOULD HAVE FOUR TERMANALS ON IT RUN YOUR NEGATIVES TOGETHER THEN RUN YOUR POSSITIVES TOGETHER AND SEE IF THAT WORKS! GOOD LUCK!!!!!
Oct 22, 2010 | Koiiler XM-6666W Car Audio Amplifier
Hi... When I adjust my radios balance to full right or full left, it gives far stronger bass then it would if the balance were dead center.... When it is centered, there is very little bass......and music...
speakers are "out of phase", meaning that one side is wired correctly and the other side is not. the easiest way to fix this is to just switch the wires on one side, by "switching" the wires i mean the positive and negative wires on the speakers/box? hope this helps, dave
Oct 11, 2010 | Koiiler XM-8787C Car Audio Amplifier
My koiiler fuse is bad how much is one
you will want the one with the 40 printed on it
and you can get them from 1 to 5 dollars depending where you buy on the internet
Sep 27, 2010 | Koiiler XM-7676W Car Audio Amplifier
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
What size fuse does the XM 7676W Car Audio Amplifier take? mine blew and i got the amp from a friend so i dont know?
Do not use anything bigger than a 10amp fuse. Cheaper to replace a fuse than an amp. 10 amp is usually the standard.
Apr 25, 2009 | Koiiler XM-7676W Car Audio Amplifier
Car Audio & Video Logo
71 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
