Question about Yamaha RX-V1200 Receiver
Volume knob quirks
The volume knob on my rx-v1200 is hardly functional. Turn it to the right, and the volume jumps up and down within a short range. If you're lucky, it might track well and adjust properly, but this is so rare that the knob is almost useless.
I can only adjust the volume on the remote, and even that is now becoming difficult. All other remote functions seem to work fine, but the volume adjustment has to be held for a long time, and then the volume makes a fast adjustment. No individual "taps" for smaller adjustments.
Is this a common problem? A cheap/expensive fix? Something I could fix if I take it apart and replace faulty parts? Any input or direction would be great!
  • freemizzle May 05, 2008
    is there any site where i can find some sort of schematics or guide for opening up the receiver and locating these parts? or, any tips for where i might purchase replacement parts (volume control switch)?
  • danielhumby Dec 10, 2008
    I have the same problem with a Yamaha RX-V430. I was told that it could be a number of things, but unlikely to be the physical knob itself but more of an electronics problem some where...
    Did you end up getting this fixed??
    Novelist:
    Champion:
  • 236 Answers
If you know how to repair, then replace the volume control switch. it is a digital type/mechanical type of switch with silicone oil on it to prevent sudden turn of volume. if i were the repairman i can simply clean the contacts of the volume control and pour silicon oil again. but i really dont know in your area if they try to clean those.
Posted on May 03, 2008
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
Yamaha RA-V1200 wont turn on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happened to me on RX-V592
Jan 16, 2013 | Yamaha RX-V1200 Receiver
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
No sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
May 05, 2009 | Yamaha RX-V690 Receiver
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
AV receiver RX-v1200
What happens when you turn it back on?? Are there any messages on the display??
Jul 03, 2008 | Yamaha RX-V1200 Receiver
Yamaha rx-v1200 volume control
if you are not really that technical type that can make repairs then it will be very hard for you to replace it yourself. not hard to find the volume control, it is mounted on a board. you dismantle the board first then remove desolder the volume control. it think you can onyl get the parts from yamaha service.
May 05, 2008 | Yamaha RX-V1200 Receiver
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V1200 Receiver Logo
399 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
